Question about Whirlpool GH4155XP Microwave Oven
No power we have reset the braker, check the outlet, they are both function properly. Any other suggestions
    Problem Solver:
  • 11 Answers
It could be a fuse or the control panel. You should be able to take off the top plastic grill with two screws and then you should be able to get the whole control panel off. You should be able to see a fuse in there(probably black). You can get the fuse anywhere and it's cheap. Control panel... not so cheap.
Posted on Jan 28, 2009
Started tripping the GFI outlet. Outley appears to functioning correctly after re-set, but the microwave keeps tripping it when I plug it back in
HI Joe
Couple of things to consider here.
  1. There may be a GFI plug there at the microwave, but it can get tripped by current leakage on other parts of the circuit. If there are other things plugged into the circuit (every outlet that's on the same panel breaker), it's possible any of them could be causing the tripping. Unplug anything else on the circuit, then plug things back in one by one to see if there's something that may make it pop.
  2. The reset switch in a GFI plug is mechanical. If it's been tripped a few times, it may be worn or not fully reset. Electrical guides usually suggest testing / resetting GFI plugs monthly, both to make sure they work, and also to cycle the mechanical switch. If dust, toaster crumbs, or other stuff might have gotten into the mechanism, it might not be mechanically resetting properly. Try test/reset/test/reset a few times and see if any of the clicks start feeling more distinct.
  3. The trip can be legit. Hopefully not the microwave, but if there is a short in the line somewhere, you really want to track it down before it causes a fire. In some cases, even heavy dust on/in outlets can cause pseudo-shorts with some current trickling to ground. GFI switches will usually trigger with less than 5 mA of current drop, so it doesn't take much. Blow out the receptacle with canned air.
The switch or it's connections may be bad. Unplug the microwave and (no cutting corners here), turn off the breaker to the plug. Undo the faceplate and mounting screws and pull the plug away from the wall. Check that the wire connections to the plug are tight, and that the wire nuts connecting the plug to the wall lines are also firm and tight. Tighten if necessary. If you're still getting trouble after trying this all, Consider replacing the outlet and seeing if that helps.
Hoping this helps!
D
Dec 07, 2015 | In Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
My microwave/convection oven will not heat up, but the lights and clock work
Hello
Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
Replace or reset the circuit breaker or fuse if blown or tripped.
Unplug the microwave and wait several seconds before plugging it back in to reset.
Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
After a power failure recently my oven pol662s will not work the internal grill does but not the oven please help maybe a reset????
According to your problem first check all electric input of the oven check the power cord and ac outlet also. Reset the Oven. Reset the program properly. Check the fan of the oven. If all are ok then open the oven and check the wiring of the oven portion. May be there is any problem in wiring or circuit. Call any nearest technician.
Aug 02, 2011 | Microwave Ovens
Quit working totally. Checked outlet and have power. Is there a fuse in the oven itself? Reset Switch?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 07, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
No power but outlet is functioning properly
There is a ceramic fuse inside the oven. Remove the case and follow the cord from the back of the oven to the fuse. Replace with on of the same amp size.
Jun 19, 2010 | Goldstar MV-1501 Microwave Oven
Sharp R510AK Carousel Microwave
Very common problem with the display. It may or may not eventually light back up on it's own.
I would suggest contacting www.microwavedisplay.com. Lots of info and the best deal going for repairing the display.
Jul 03, 2008 | Sharp R-510HW Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
51 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
