-   I have the same problem. Seems that the drive shaft is now fused to the grinder blade. The whole thing is kind of flimsy, so I'm not sure how much force it can take and I can't find any release points aside from the lift tabs, which are now essentially useless.-   geoarkie
Popular Solutions for Cuisinart DGB-300 Coffee Maker
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have...
(More)
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have follwed the steps in the manual. It doesn't make any noise as if attempting to grind. The grind processed is by-passed going straight into the brew mode. We used the non-grind for about 2 weeks. Thank you.
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go,...
(More)
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go, but now just beeps again. All parts are in place and water is in resevoir.
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of...
(More)
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of coffee - just started doing that. Unit was cleaned 3 months ago. Fred
