Question about TP-LINK TPLink TLWA5210G 24GHz High Power Wireless Outdoor CPE IEEE 80211 bg Up to 50km Wireless Ra (TLWA5210G)
Tplink 6 km link
Cant achieve 6km link using tplink 5210 in bridge ap mpde
Tp link 5210
Try to update the firmware.Here is the link TPLINK
Download for TL WA5210G V1
Mar 25, 2014 | Computers & Internet
How i can change ip address of tp link 5210g throw ethernet cable
ok , need to assign your computer a Static IP address within the same
range as the AP's IP address, ip address of AP is : 192.168.1.254
the ip address for pc such: 192.168.1.253, then open your browser and write the ip address of your AP then you will be inside it .
Jan 10, 2014 | TP-LINK TPLink TLWA5210G 24GHz High Power...
Tp-link tlwa5210g wireless single not flashing
check SSID , if shown ,, the problem with electricity ,, if not shown ,, check antina , if not shown ,, reset AP ,, configure agian ,, if not shown ,, replace AP
Dec 20, 2013 | TP-LINK TPLink TLWA5210G 24GHz High Power...
Tplink third party firmware
Possibly, It all depends upon the chipset and hardware. I would check out dd-wrt.com they have many guides and good user forums that may help you. the dd-wrt is an open source firmware that if applicable worked great for me on some rather shoddy OEM devices.
Nov 05, 2013 | TP-LINK Computers & Internet
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
CAT 5E DISTANCE
Considering what you started with, it should be slow :-)
If this were my installation I would run HUGESNET>Router>BRIDGE>BRIDGE>ROUTER/AP>PC
The first router is the 150N. The Bridges are two Wireless Access points in bridge mode designed for distance. A nice unit for this application is a TP-Link WA-601G with antennas (ANT2408) found here:
http://www.tplink.com/products/wlan.asp
It will cost you an extra $100-150 depending on antenna, but it should get you good results, considering the SAT is probably 300 down and 128 up :-)
Carl
Apr 05, 2009 | Computers & Internet
Using the DI-624 as a bridge
I don't think it can. An inexpensive wireless access point will work as a bridge. I use the TP Link brand with detachable antenna.
http://www.tplink.com/products/product_des.asp?id=116
Using the terms using the dlink router as bridge you get results of people who claim it can't be done because of firmware. The same question on the D-Link help site mentions DL to DL bridges, but not with the 624.
Carl
Jan 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
TP-LINK TPLink TLWA5210G 24GHz High Power Wireless Outdoor CPE IEEE 80211 bg Up to 50km Wireless Ra (TLWA5210G) Logo
24 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
