Crown victoria 2006 Car Air conditioner/heater not working... It's not the switch or fuses. Help plz
  • 3,904 Answers
After watching your video it would appear the problem is that your blower is either bad or a fuse popped. In your owners manual it will tell you which one is for the blower.
Posted on Jan 23, 2013
  • b4bygis3ll3_ Feb 02, 2013
    Thank you. You were right, it was a bad fuse...
  • 51 Answers
SOURCE: Heater works fine but when you turn on Air
MOST LIKELY NEEDS NEW BOARD , THERMOSTAT , TRANSFORMER , MAYBE FUSE ON THE BOARD AND
CHECK FOR WIRE BREAKS AND PROPERLY CONNECTED WIRES
AND IF IT STOPS THAT SUDDENLY THE COMPRESSSOR MAY
BE BAD SO CHECK FOR A GROUND OR TRIPPED BREAKER, AND
BURNT WIRES..CHECK FOR SIMPLEST 1ST. NARROW IT DOWN
AND MAKE SURE OUTSIDE UNIT IS RECEIVING POWER AND
CHECK CAPACITOR. LOOK AND CHECK FOR DISCONNECTED WIRES INSIDE AND OUT.
Posted on Apr 13, 2010
walterkunesk
  • 683 Answers
SOURCE: my air conditioner blower stop
you have a direct short in the system.
Posted on Feb 22, 2011
  • 230 Answers
SOURCE: We have a Coleman Evcon
Check your stat. is it set properly on cooling, and low enough to turn the unit on, with power on and the stat calling for cooling you should at least get the fan and the out door to kick on, if not your stat or the transformer could be bad. there is a reset on the transf. on some of the unit that could be tripped
Posted on Jul 04, 2011
  • 413 Answers
SOURCE: i have a question about
Could be just a blown fuse or circuit breaker. Fuses are generally located close to the unit in a small box on the side of the house. You will have to flip the box open to find the fuses. It may have a cartridge you have to pull out. Fuses are not visibly bad, you have to check them with an ohm meter or sometimes a hardware store can check them for you. Otherwise you will have to buy two and just replace them both.
The circuit breakers are usually in the house along with all the other breakers in a main panel. There will be two breakers and will probably be visibly tripped. Just flip them all the way back and forward to reset
Posted on Aug 03, 2011
Testimonial: "thanks I will check it out!"
heatman101
  • 43501 Answers
SOURCE: The heater works just fine,
The heater works on an electric coil...
The A/C must run the compressor...
If A/C does not work then the compressor is not working...
heatman101
Posted on Aug 13, 2011
My heat works but it is blowing any air
have your blend motor checked and you blend door
Nov 08, 2011 | 1996 Ford Crown Victoria
The windsheild wipes, windows, radio, and the heater/air went out on my 1999 ford crown victoria. the head lights still work though. the fuses look good. what do you think it is.
HAVE DEALERSHIP CHECK IT OUT YOU HAVE EITHER ELECTRICAL PROBLEM OR PCM PROBLEM SINCE WINDOWS , RADIO, AC AND HEATER CONTROL CONTROLLED BY PCM.
Sep 30, 2011 | 1999 Ford Crown Victoria
2006 crown Victoria blows hot air with the air conditioner on the air condition lines are cold under the hood
sounds like the temperature blend door is either jammed or the actuator is shorted ou. when the temperasture control is moved you should hear the door moving...my guess is you are not hearing that..the actuator would be attached to the heater plenum behind dash/glovebox area...becareful to test the correct one as there will be a fresh air actuator and a mode door actuator as well...you can determine which one is which by changing the positions on heater head from hot/col, floor/defrost, recirculate and fresh air settings..each setting will move its designated actuatror..the one not moving would be you temp actuator....have fun!
Jun 29, 2011 | 2006 Ford Crown Victoria
I have a 1999 Crown Victoria. When I turned the heater on, the fuse blew for the low beams and signal lights. Heater works fine and amperage is ok. Replaced fuse, still no lights. Solutions?
It was recommended that I replace the multi-function switch. This I did not follow.
In the end it was the AC relay switch that was defective and needed to be replaced.
Oct 27, 2009 | 1999 Ford Crown Victoria
1998 Crown Victoria air conditioner
Fuse 9, 50A under hood, Fuse 5 15A Instrument panel. If they're ok, make sure the compressor clutch can be turned by hand (engine off, obviously). If not replace the compressor. Most common problem is the cycle switch. That should be the electrical connector on top of the accumulator. Just jump that by backprobing the connector on both sides with a pinand connect them, with the car on and a/c on if the compressor clutch engages, replace the switch. If it doesn't, try wiggling wire harness and watch it, if it engages, find a broken wire and repair it.
Aug 11, 2009 | 1998 Ford Crown Victoria
I want to recharge the air conditioner on a 1992 crown vic
find your evaporator inlet outlet lines on the fire wall usually near heater core inlet outlet lines. then follow both lines until you find the one that goes to the compressor. that is your low side and the port should be on there
Jun 26, 2009 | 1992 Ford Crown Victoria
When a/c or vent is on, heater will come on blowing hot air. 1996 for crn vic. Regardless of the temp setting.
I have the same problem and asked an air conditioner mechanic what he thought. He said that the problem is a bad module under the dash that works a door that guides the air through the heater core or switches to the air condenser by the dash switch. He told me he could not fix it because he was too old and it would take a young man or woman to work under the dash.
Apr 27, 2009 | 1996 Ford Crown Victoria
2006 crown victoria - no heat
I would change the thermostat in the vehicle first and go from there. Hope this helps......Dan
Jun 20, 2008 | 1999 Ford Crown Victoria
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
