Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
How to remove the hoover windtunnel handle release lever
This part is broken on my vacuum. I have the replacement part, but can't figure out how to remove the old part so I can install the new part.
    Scholar:
  • 108 Answers
Tilt the handle back and pry it out with a flat blade screwdriver.
Posted on Jan 25, 2013
2 Suggested Answers
SOURCE: The handle release lever (Part N. 38434-021) on my
You can buy Hoover Handle Release Lever 38434-021 at
http://partsreadyonline.com/item.php?ItemID=798
Posted on Jan 10, 2011
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
The grey pre-filter catch broke and we ordered a new one. now we don't know how to install it.
I just successfully completed this replacement on a DC33 (the prefilter catch is blue on this model.) Not sure how different the assembly is from the DC07 but thought I would post: If you turn the vacuum over there are two screws that loosen the exhaust pipe--one you can see and one up a small shaft (which also loosens the cowling just under the cyclonic assembly.) Both will require a driver or allen-style wrench with a medium-sized star head. Remove both and you will be able to take off the exhaust pipe. You'll need to pull back the aforementioned cowling a bit as you do this. Once the exhaust pipe is off you will be able to see the bottom of the prefilter catch. You'll notice five tiny bays--if you shine a flashlight through you'll see that between bays 2 and 3 there is a small catch (you can note it at the bottom of your replacement prefilter catch as well.) Shove two extra small screw drivers (like the size you get in eyeglass repair kits) into bays 2 & 3, then gently press down on the driver handles to release the catch. A little pushing at the same time will remove your broken prefilter catch. DON'T INSTALL YOUR NEW CATCH YET! Otherwise, like me, you'll have to immediately remove it to reinstall the exhaust pipe :) This was the most time consuming part of the whole operation, as you kind of have to fenangle it a bit to get it back on. Be patient and don't forget to pull the cowling back again while you're doing this. Once it's back on, realign the cowling at the top of the assembly and replace the screws. Then you can turn the vacuum upright again to easily snap in your new prefilter catch.
Nov 03, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to remove and replace dyson DC07 frame assembly plastic housing, I have the new frame assembly, but can't figure out how to remove the old one.
As this procedure should only be carried out by a Dyson engineer, unfortunately we can't provide instructions on how to replace the casing of your DC07.
If you'd like to arrange for your cleaner to be serviced, you can do so by calling us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor making strange noise. How do you take apart a dirt devil featherlite bagged vacuum cleaner down to the motor. I can't get the red cover off the vacuum.
With most vacuums it's not necessary to completely dissassemble to the motor. Most rattles are either something stuck/jammed in, around the wheels and intake area. The rattle, if it's a knocking can also be the internal broken rod of the roller. Rollers can be purchased at hardware stores. Even Walmart and Target carry many models. There are screws in the back and front and guide tabs that the housing cover slips into in the front to remove the top cover as a last resort.
Try cleaning maintence 1st.
1) Unplug
2) Flip over and remove screws on the belt and roller face. Remove face-expose belt &brushes.
3) Slide brush out of grooves. If the belt makes you nervous, slide a large screw driver through it's loop to hold in place while you clean the roller.
4) See if the belt is in good condition free of cracks or tears. If it needs replacing, it slips over the motor spindle for simple change outs. The belt and roller part number should be listed on the vacuum if you look atround. Usually on a metallic plate installed during manufacturing.
You can take a 4' length of old garden hose and listen through it to the outside of the motor while running to see for sure if the noise IS coming from the motor, or infact it's the roller. I hope this helps you.
Sep 22, 2011 | Vacuums
Thump thump noise
A loud rattling/thumping is usually a broken internal roller support rod. You can check by: UNPLUGGING the vacuum, flipping it over, taking the screws out of the roller brush cover plate and removing the plate. It goes back together the same way. If you are nervous about taking it apart, take phone pics step by step as you go so you can see exactly how it came apart for re-assembly. After removing the plate you will see the belt. Pull the roller forward, it will slide out of it's grooves and come out. Slip the roller out of the belt & shake it. It shouldn't rattle, if it does..it's broken inside. Many parts are available at Walmart. If the belt comes off it just slips back on over a metal pin further in the back-you can see it. Use a flat blade screw driver to slip it back on. Slip the new or old one back unside the belt, then back into the grooves till in place. Then the cover & it's screws. You should be back in business!
Sep 04, 2011 | Vacuums
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover Upright...OLD vacuum, broken belt
The rod must be your brush roll. it should just pull out, Have you removed the cover over the brush roll? When you do get the brush roll out, turnb the ends and make sure they turn freely, if nit, replace it also.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Bissel 3594-1 release lever
Flip over the vac and use a long skinny screwdriver to spread the tabs that capture the two nubs on either side of the lever then pull the old part out. Then simply align the new part, and press it down into the slot till it clicks in place.
Jul 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Cannot get new belt on
no need to remove motor shaft which is integral with motor. slip belt on motor shaft first, then on roller then pull roller back to correct position. needs a little force
Jun 06, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
446 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
