Would not Copy Duplex Anymore
I could copy duplex before but now i cannot copy both sides anymore
can some one help me out!
  • Anonymous Jan 28, 2009
    ok but when i checked on the printer self i Select duplex copy but still nothing
  • adonius4ever May 07, 2009
    But still won`t copy duplex
  • 142 Answers
Hi, you will have to check your settings , either in the printer, or in the software, to ensure that duplex copying/printing is selected.
cheers
Posted on Jan 28, 2009
Why does xerox work center 5020 copy only and yet the duplex is okay
Hi Wandekera,
I think you have a operator error problem. If the duplex is working then there is no mechnical problem have you got 2 sheets to copy then you should still have something on both sides of the paper.
Further investigation would be necessary.
Good Luck.
May 04, 2015 | Xerox Office Equipment & Supplies
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
I am having a 6551 canon copier and I am getting the problem in the duplex. When I am taking copy in overlay mode. the over lay mode first copy is coming and when the paper is in duplex. the second copy is...
sounds like the registration rollers and the duplex rollers need to be replaced. they have finnally gotten worn out to the point that single sided copies are fine but the paper slips during the duplexing and offsets the copies
May 17, 2010 | Canon NP 6551 Black and White Copier
How do you print on both sides of a sheet of paper
Unless you are using a duplex "Multifunctional" copier(with fax.) most plain fax. machines are not duplex and will only print on one side of the page.
If you have a machine capable of rx duplex printing please specify make and model for additional help.
Mar 22, 2010 | Office Equipment & Supplies
How to make automatic duble sided copy on IR-2000
these machines have a duplex unit all machines this size does, now a duplex unit is where the paper double sides in the machine, like doing a double sided copy.
i know off some people think that a duplex unit is the DADF (document feeder).
May 31, 2009 | Canon imageRUNNER 5570 Copier
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
113 people viewed this question
k24674
jasbo
jasbo
