Question about MSI Wind U100-030US Laptop
7200mAh, 9 cell battery won't fully charge more than 58%
  • MSI Master
  • 7,627 Answers
Replace battery
Posted on Jan 23, 2013
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Not starting up
hello there!
so you're phone won't charge up...you should buy a new battery...your old battery is not functioning well...
tip:
don't use the phone while charging. let it be fully charge before using it again. and don't let it to overcharge too. this will reduce the life span of the battery.
Thank you for choosing fixya and kindly rate this post.
Dec 30, 2011 | Sony Ericsson Cell Phones
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
Sir, my phone is Samsung gts5233w. Since a week it has got some problem with its battery.The battery gets low after 1 day,when it is fully charged.also i cant find "POWER SAVING MODE" in my...
Jul 24, 2011 | Samsung Star GT-S5233 Cell Phone
I bought brand new laptop dell inspiron 1525 and now battery looking damage in less then one years. I need some reliable source where i can purchase quality battery with reasonable cost
I have used a web site for purchasing several replacement laptop batteries, it's called richbattery.com. Both the branded and richbattery.com batteries come with same warranty, both are new, both are the same rating, money back guarantee and I would bet both come from the same factory in China!!! . Try this http://www.richbattery.com/New-Battery-for-Dell-Inspiron-1525-7200mah-9-Cell-Laptop_p_58649.html i hope it helps
Jul 10, 2011 | Dell Inspiron 1525 Laptop
My battery on my ASUS Eee PC 1005HAB died. Also, the Battery Charge Indicator stop working, I since replaced the battery with An ASUS 7200mAH battery. I ran it down till it was drained and tried to...
Check the voltage at the pins of the adapter. If present accordingg to the specifications then connect to the laptop and remove the battery from behind. Now check the voltage at the battery terminal of the laptop. if there is low or no voltage to the desired level then there are problems within the main board as this insufficient voltage will not charge the battery makeing it go down below level.
Jul 09, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I replaced my toshiba battery the 4000mAh to a new one 7200mAh 9 cells but it is not charging on windows its only charge when i shutdown the computer but the win 7 shows me that the cable is plugged in but...
The charger that you had for the 4000mAh battery was strong enough to charge and power your laptop at the same time.
Now that you have increased the capacity of the battery you need a charger that is powerfull enough to charge the battery and power your laptop.
You need to purchase a stronger charger/power brick.
Take care!
damnor01
Apr 24, 2011 | Toshiba LiIon 7200mAH 9 Cell Battery
MSI Wind U100-030US Laptop Logo
57 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
