Question about Kenmore Washing Machines
Why did my washer leak when it wasn't running?
He4t, washer located in unheated room
  • Kenmore Master
  • 17,129 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Posted on Jan 24, 2013
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elit HE4t Front Load Washer leaking from rt side of tub
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question##$$
Posted on Oct 01, 2010
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Washer won't unlock flashes f14.....Kenmore Elite HE4t
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
Jul 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Error code FH on my AWM, what does it mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
Water is leaking from the rear of the drum on our Kenmore HE4t. I've had the back off the machine - there is black (grease) running down from the hub, water leaking from there down onto the floor. How...
that would involve changing the outer tub (the only way to buy the tub seal) and the inner drum. big job and very costly as any warranty is from sears and they will only give you parts for free if you pay them to put them in for you too.
Feb 07, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Apr 26, 2009 | Kenmore Elite 45986 Front Load Washer
What is kenmore he4t button sequence for
If the washer does not come equipped with a "Clean" cycle, then run the washer on it's hottest setting. "Sanitary" or "Whitest Whites" will do. Hope this helps.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
