Question about Lasko 1850 Stand (Pedestal) Fan
My lasko 1320 fan just stop working, no burnt smell
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
  • 5 Answers
SOURCE: lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Posted on Jun 11, 2009
  • 347 Answers
SOURCE: my lasko fan stopped working after a power outage.
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Posted on Aug 30, 2009
  • 15 Answers
SOURCE: Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Posted on Nov 09, 2009
SOURCE: Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Posted on Jun 10, 2010
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
Jul 28, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
What wrong my wind machine stop working and had funny smell?
Well,,, if it had a funny smell,,, along with not working anymore, than either a wire burned up or the motor fried. I'd bet on a wire though. If its multi speed, than a capacitor may have fried too but they don't ordinarily smell unless they burn. For the price of a new one,, just go out and buy one instead of wasting money on a repair unless you know someone who can fix a small problem.
Jul 17, 2014 | Lasko 3300 Wind Machine Fan
My fan only works on the high setting. how do i
The control panel contactors have more than likely burnt
Jul 06, 2010 | Lasko High Velocity Space-Saving Blower...
No heat after burnt smell
Either your Fan motor is faulty or the fan control resister assembly is burnt out, either of those will cause the smell.
Dec 28, 2009 | 1999 Cadillac DeVille
Lasko fan will not ocillate
check the oscillating gears usually made of plastic
Aug 28, 2009 | Lasko High Velocity Space-Saving Blower...
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
Lasko 3723 burnt motor
sorry but you need to purchase a new fan.
some times the motor is not aline correctly and the rotor "part that spins the blade" rubs on the stator "the part with the copper wire:" the motor
over heat with the friction, then smoke followed by the coil burning.
Jun 14, 2009 | Lasko 3723 Floor / Box Fan
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
Lasko 1850 Stand (Pedestal) Fan Logo
42 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
