Question about MixSonic MX-31000 (1 GB) MP3 Player
Not turning on
I went to turn my Mixsonic 1GB MP3 Player on and nothing worked. No lights, nothing. I put a new battery in and still nothing. I've only had it for 4 or 5 months. Any ideas?
  • 4,102 Answers
Try plugging the usb lead in and dont press  nothing on the mp3 player plug it into your computer it should switch itself on and you should be able to open the file on your computer and see whats on it if this dont work then it is beyond repair if it comes on and your computer can download files off and onto it then its is a battery problem might be that a wire has come off the battery terminal if this is the case and it works when plugged into your computer then it is possible to repair it you will need to take the case off and look at the wires that go onto the battery terminal this is usually the problem but to repair it you will need a small soldering iron but it would be cheaper to get to an electrical shop and they should do it for you for about 5 to 10 pound if it dont work when plugged into pc then ii is beyond repair sorry hope this is not the case good luck hope this is some help to you.............
Posted on Oct 30, 2007
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
No problem jusst wanted to know if the mixsonic
I'm taking a look at the Amazon page for the player: and I see no mention of a timer record feature. Hope this helps.
Mar 04, 2009 | MixSonic Aim (1 GB) MP3 Player...
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
Won't Work suddenly.
What is happening when you turn the device on? Does it go on and then shut off? If so you will have to reformat the drive for the mp3 player. Simply plug the mp3 player in and click the drive that appears for the player. It should say this device needs to be formatted. Then just follow the steps. Keep in mind you will lost your songs. If the device stays on, do you see your first song on the list. If you do, try pushing the play button, (very last one on bottom) hard.
Dec 08, 2008 | TruTech SMP-1 GBL MP3 Player
Coby MP3 MPC882
Ok people the problome is in the head phone jack. It don't make proper conection any more from being twisted and wiggled around all the time. What you can do is take the mp3 apart and put a little pice of paper and fold it upon top of the head phone jack and put it back together. Make sure that the paper is still thick enough to push down on the jack. You might have to get two extra screws of the longer two types. just in case. Any comments e mail me at:
Oct 25, 2008 | Audio Players & Recorders
Ilo mp3 player
ilo 1 GB MP3 Player ~ Hardware Help.this page should help you out,it doesn't matter that says 1gb it does for all
Jan 25, 2008 | iLO (2 GB) MP3 Player
MixSonic MX-31000 MP3 Player
are you using it through the usb lead if you are you should be able to open the file on the mp3 this should allow you to delete leave this file open but put the music you want on it in a shared file then open this file alongside the file on your mp3 this should allow you to drag and drop but try doing this with your mp3 switched off before you plug it in make sure its off and then when you plug it in it should switch itself on but dont touch the mp3 player and you should be able to drag and drop the files make sure their is enough free memoy on mp3 s some music files are massive you wont need to touch your mp3 player at all while it is plugged into your computer and it should work with no battery in it hope this helps
Oct 30, 2007 | MixSonic MX-31000 (1 GB) MP3 Player
Mp3player won't turn on
hi , i have an mp3 player which has been working fine all along. i shut it down,a few minute later trying to put it on only the light is on but nothing displays and sometime just shows sandisk and it hangs it not gives any responce
Mar 31, 2007 | SanDisk Sansa e250 MP3 Player
MixSonic MX-31000 (1 GB) MP3 Player Logo
Top MixSonic Audio Players & Recorders Experts
Are you a MixSonic Audio Player and Recorder Expert? Answer questions, earn points and help others
