Question about Bernina Sewing Machines
How can I take the back of my bernina 1030?
The wheel started to squeek and then turn really hard, finally it stopped moving altogether. When I peer throught the thread take up hole I can see a place where thread is twisted around. It looks as if it has jammed the turning mechanism. I would like to take the back off and try to clear the twisted thread. I took 4 screws from the back and 2 from the hand wheel. It still is held together on the bottom left side. I would like to take this panel off.
  • Bernina Master
  • 2,100 Answers
Bernina 1030 Service Manual Page 5
If you click the tiny page pictures on this page they expand. Page 5 discusses taking off the back.
Posted on Jun 17, 2017
4 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: consew 226 r sewing machine
Take the bobbin out and check for dirt or broken thread in the hole.
Posted on Sep 15, 2008
SOURCE: balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Posted on Nov 17, 2008
  • 8 Answers
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
Posted on Jul 18, 2009
I have a Bernina 1030. When I put a presser foot #57 on the needle hits the presser foot. The presser foot covers the wide hole in the back.
Hm, I'm at a loss here unless the presser foot you have is not the correct one for your machine. I believe some presser feet for older Berninas may not work on the 1030-1230 machines. If you have the original #37 1/4" foot for your machine, you might compare the differences between the two feet and you might see where the problem lies.
Understanding Bernina Sewing Machine Shanks Sewing Parts Online Everything...
1 4 INCH 37 PATCHWORK FOOT for BERNINA OLD 830E 830 817 eBay
FWIW, I have both the #37 and #57. The #57 (or actually any of the 1/4" presser feet that are touted as "accurate 1/4") really does not solve the "scant 1/4" seam" for quilting because it still makes a 1/4" that is too wide. The best method I've found is to set a ruler under the presser foot. Set it so the needle tip rests lightly on the 1/4" mark and then mark the outside edge of the ruler with painter's tape on the needle plate. Then use the edge of the painter's tape as your 1/4" edge. If you find your 1/4" is still not "scant" enough, move the painter's tape a tinge until you get it where you want it.
https://www.connectingthreads.com/tutorials/How_to_Sew_an_Accurate_Quarter_Inch_Seam_Allowance__D95.html
Dec 08, 2017 | Bernina Sewing Machines
I have a Bernina 1030 and the size of the straight stich knob is jammed it willonly turn back to 1 which means it will not straight stich just a small zigzag. Can you please help.thanks Joy
I suspect the machine's stitch selector mechanism has seized due to old, dried oil. (I have a 930 and several older Bernina models, and oiling thoroughly and frequently is necessary to keep these nice mechanicals running smoothly.) However, if the knob on the straight stitch selection lever is frozen, you may need to take it for service if you are unable to free it on your own.
Wheel on right side that controls the needle up and down is very tight...
Aug 08, 2017 | Bernina Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
My bernina 1030 is not feeding the fabric, it is sewing in one place
Make sure your feed dogs are not set for free motion or darning. Once you switch them to regular sewing you will need to turn your hand wheel 1 rotation for them to come up. Also make sure that your stitch length is not set at 0.
Jan 07, 2015 | Bernina Sewing Machines
The upper thread is constantly breaking. Don't know how to fix it. Any suggestions?
Check the tension for upper thread and bobbin(tiny screw to turn anticlockwise to give less tension)
Nov 18, 2014 | Bernina Sewing Machines
Please could you tell me the age of the Bernina 1020 and the 1020
Find the serial number, engraved into the metal on the back of the machine or low down on the hand wheel end.
First digit is the decade: 1=1970's, 2=1980's, 3=1990's
Second digit is the year in the decade.
E.g. my 1030 is 27230888 so it was made in 1987.
May 21, 2014 | Bernina Bernette 75
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
I have a 1030 Bernina sewing machine and for the first time in 10 years the needle will not move up and down. It will go side to side. It stopped while sewing and won't restart. I have checked all of the...
Take it to your Bernina dealer, they should be able to determine what is wrong and hopefully fix it, free. You really do not want to do something that could void your warranty. My Bernina dealer is super nice and always helpful, they are very professional. I hope that it is just some silly thing, like mine was.
Apr 03, 2011 | Sewing Machines
Bernina 707 wheel is hard to turn
If the handwheel on your Bernina 707 is hard to turn, it most likely needs a good cleaning and oiling. Old oil dries and tends to get gummy, causing the moving parts to be stiff.
Oct 01, 2010 | Bernina Artista 180
Sewing Machines Logo
54 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
