Question about SanDisk Sansa MP3 Player
My computer will not reconize my sansa express and display is brk
My computer, or sansa updater, will not reconize my sansa express and display is messed up the display looks like you split it and swapprd the bottem for the top half, and one half is blue the other is yellow.
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Jan 29, 2009
I was listening to the player and it all of a sudden wouldn't shut off and it wouldn't charge, after 2 days it charged and i was able to get into the files but it wont let me delete the files and says my...
When the Sansa Express keeps freezing you can RESET the device using next step:
note:
The device can be either on or off, player NOT connected to the computer:
Press and hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
When the "rebuilding database" message keeps coming back, the player will need an update.
Use the Sansa Firmware Updater (works on Windows only) or go for the matching download on the forum:
http://kb.sandisk.com/app/answers/detail/a_id/446/kw/database/p/555%2C662%2C687/r_id/101834
The Sansa Firmware Updater will contain the driver for the computer to perform a firmware update on your player [ METHOD 1 ].
When downloading the driver package manually, first put the driver "StMp3Rec.sys" in the correct folder on your computer. Next start the SansaExpressUpdater [ METHOD 2 ].
During this update, connection between player and the computer is based on MTP mode, Media Transfer Protocol: Drivers and software are needed to get access to the player.
The player could also be accessed in MSC mode, seeing the player as a removable disk. How to get connection in MSC mode, see next link:
http://www.machinist-toolbox.com/SansaExpress_MSC-Mode.pdf
Manual for Sansa Express:
http://mp3support.sandisk.com/downloads/um/express-userguide-en.pdf
Support site for the Sansa Express:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9nWWpkcGYqag%3D%3D/sno/0#express
May 19, 2010 | SanDisk Sansa MP3 Player
Sansa express won't turn on
Normal 0 Press and hold the Volume Up (+) and Select buttons at the same time for about 20 seconds
Make sure that the player is charged up.
Try to power reset the device by pressing and holding the center and volume up button at the same time, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
You may need to update firmware.
Feb 07, 2010 | SanDisk Sansa MP3 Player
Sansa express player does not respond, looks like it's off (screen is black) but when connecting headphones it makes the sound as if a song is paused, computer can't see it so its impossible to format. ...
Try and do what is called a Power Reset. To power reset the device, simultaneously press and hold the center and volume up button, while connecting it to the PC.
If this fails, charge the device for at least two and a half hours. The computer should not go into sleep or hibernation state while charging.
Then you may want to update the players firmware by downloading and installing the Sansa Firmware Updater.
Jan 30, 2010 | SanDisk Sansa MP3 Player
My pc will not reconize my fuze after i updated it
Send it back beacuse their is no syncing method to be seen with in the computer.
Jan 25, 2010 | SanDisk Sansa e200 MP3 Player
Computer won't reconize my sandisk mp3 player
Hi, just had the same problem after restoring my system.
You must disconnect and update your Windows Media Player to Number 11. My reinstall left me at WMP 9 and it wouldn't recognise my Clip. Go to the Windows website, follow the download instructions, and you should be fine. When you plug in the Sansa Clip or MP3, it should recognise it right away. Hope this helps!
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
Sansa wont turn on/isnt reconized
I will recommend you to get a firmware upgrade for the device...if that doesnt do it, you will need to contact the manufacturer so they have RMA the device,usually update the firmware solve the problems you are having...
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 1 gig mp3
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Dec 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
