Question about Husqvarna Viking Designer 1 Embroidery Arm Attachment Unit
Needle clamp screw broke off
The needle clamp screw - the screw/knob that turns to hold the needle in - broke off with most of the threads still inside the hole...do i need to change the whole needle clamp, or is there a way to remove the thread part from the whole to use a new screw?
  • Gina Lasseigne
    Gina Lasseigne Jan 23, 2013
    product is not id'd correctly.....I am referring to the designer 1 machine itself...and not the embroidery arm unit
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
I have a singer futura XL580 and the thread guide either flew off or broke off. I thought I bought the right replacement part no. 086046 but can not seem to figure it out
That is because the thread guide is underneath the needle clamp, and BOTH must be removed and replaced together as a unit. In addition, the wire is held by a tiny screw in the back of the shaft. That screw also serves as the stop for the end of the needle. Take a look at the shaft right above the needle, and you'll see what looks like a grey bar--that is the screw. It's difficult to access on the back, but must be loosened first -- JUST ONE OR TWO TURNS -- to remove the wire. Then, take off the needle clamp and wire as one unit.
Insert the replacement guide inside and at the back of the needle clamp, with the hook part sticking out of the clamp. You'll see that there's an indentation in the clamp to hold it. Insert the guide and clamp as one unit, then hook the wire around the screw and tighten.
FYI - If you accidentally remove the screw (which only turns about three or four times) and drop it as I did, you don't really need it to hold the wire guide, BUT you still need a needle stop. I just inserted a toothpick when I changed needles until I could get a replacement.
The above sounds relatively easy, but you'll probably have to do some manipulating, especially the first time, and if you're like me, possibly some cussing -- but it WILL fit.
Dec 31, 2016 | Singer Sewing Machines
How do I replace the small metal bits that hold the needles in place
Needle clamp & screw and maybe the thread guide all screw together. The screw that holds the needle into clamp is all that hold this on the machine. Don't over loosen the needle clamp screw when changing the needle next time.
Dec 21, 2015 | Baby Lock Imagine
Fixing a new needle on a sewing machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
wrong foot is attached
needle clamp screw is loose
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Husqvarna Designer I
My needle holder will not hold the needle in tightly what could be causing this problem?
The threads of the screw that holds the needle clamp could be stripped or worn.
The needle clamp can be replaced. You can get this from a sewing machine dealer who does the repairs or, order from the Internet.
Stretching a piece of Teflon tape (a plumbing product and not expensive) around the threads of the screw can provide a short-term fix.
May 02, 2010 | Brother XL-6562 Mechanical Sewing Machine
My needle broke. How do I fix it?
hi! there, first you have to raise needle bar to its highest position by turning the handwheel toward you.hold the broken needle itmay drop after loosen broken needle.,loosen the needle clamp screw using by a srcewdriver pull out broken needle.take new needle holding the needle with the flat side away from you.slip the needle into the needle bar groove.make certain it is up as far as it can go tigthen the needle clamp screw with a screwdriver,aas shown1b71a34.jpgregards
Mar 28, 2009 | Euro-Pro Shark 60 - 384
Husqvarna Viking Designer 1 Embroidery Arm Attachment Unit Logo
59 people viewed this question
Top Husqvarna Viking Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
Ravi
Are you a Husqvarna Viking Computer and Internet Expert? Answer questions, earn points and help others
