Question about Belling Ovens
One of the Fastlites on the hob of our Belling 626 has stopped controlling - it's either full on or off. Any suggestions?
  • Belling Master
  • 5,323 Answers
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
: I offer free advice bcuz God is so good!
Posted on May 03, 2015
3 Suggested Answers
  • 417 Answers
SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Posted on Dec 22, 2009
Testimonial: "thanks ashburton i will attempt to change the element first."
SOURCE: I have a Belling E 662. The back left hob is
Exact same problem here with the same make and model. Have not found any info on fixing it have you?
Posted on Oct 24, 2011
Hi, I have a belling electric oven and separate grill. The two hobs on the left don't work, the grill doesn't work and the front elements in the oven itself has stopped. Is it fixable? Thanks.
Go to the circuit breaker location on your house and locate the one for the oven. Try flipping it on and off a couple of times. If the breaker only supplies 120 volts the heating elements won't work but the light and clock will. If resetting the circuit breaker fixes the problem, it will happen again, so replace the breaker to do a permanent fix.
Dec 14, 2015 | Belling Ovens
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
I have a Belling E 662. The back left hob is permanently on even though it should be off, any suggestions ?
Oct 12, 2011 | Ovens
Belling oven stopped working
Dec 22, 2009 | Ovens
My hob is working but there was a bang in the oven and nothing is working inside the oven but the hobs are working fine. Many thanks for any help
If it is a fan assisted oven, and the fan is working o/k, then I would suggest that you fit a new oven element, if the fan is not working, then you are going to have to investigate further.
Please rate my solution.
Thanks.
Nov 08, 2009 | Belling XOU270 / XOU271 Electric Single...
Soot on on all saucepans when using gas hob
Adjust flame down, too high. Turn adjusting screw at control knob.
Sep 01, 2009 | Belling Ovens
Ovens Logo
82 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
