Question about Apex Digital ADV3800 DVD Player/VCR
Vcr works but when the DVD is inserted, the picture does not appear. The unit displays load...play
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
I have a go video vcr/dvd player. The vcr works dvd doesn't
if this happens to all discs needs to be repaired.my panasonic was playing up and not very old,and cost me $350.00 for a new driver.
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
The dvd player part of this unit doesn't work. When you insert a dvd it makes a sound like a dull beep as the unit appears to try to read the dvd. Then "Read" comes up on the display then there is a...
Hi
Thanks for using FixYa. When a Panasonic is giving "no read" and there are loud "clunking" or "chugging" noises this usually indicates that the lens is dirty or has failed. Other problems may include a failing or failed Digital PCB or some problem with the ribbon cables from the DVD Drive to the Digital PCB (on 2006 models such as the DMR-EZ models there is some problem with the ribbon cables to the DVD Drive on-board controller board.
Please check this picture for ribbon cable connections--
Click on the picture to Zoom In.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
Problem with dvd player in combo curtis dvd vcr
try to clean the lens with a cd/dvd cleaner available at your local stores. just insert the cleaning disk and wait until it's done. hope this helps!
Oct 15, 2008 | Curtis DVD-7600 DVD Player/VCR
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
No Picture
check out the tip in my profile or use a wet cleaning tape
Mar 31, 2008 | GE 13TVR62 Combo
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Apex Digital ADV3800 DVD Player/VCR Logo
29 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
