Question about Food Mixers
Parts list for a pinnacle avst 10 baitcast, need gear for worm gear that rewinds the line
3 Suggested Answers
ricardok45
  • 135 Answers
SOURCE: repairing a kitchenaid 6qt mixer
Hi. Go to the whirlpool.com website, for some insane reason they don't list their mixers, enter a search for mixers, then find your model #. Look for a parts catalog. Look at the "exploded" drawings for the transmission area. There you'll notice that there are Front and Rear bearing locations. This drawing also shows the correct place for the "washer". Also, the front and back bearings may look alike, but the're not. Every part needs to be in it's correct place or damage will occur when you start it up, or when you place the machine under load. Let me guess...The original PLASTIC transmission housing broke causing damage to the worm gear assembly. If this is the case, your replacement transmission housing should be made out of metal. If it isn't, call customer service and demand that they send one. The plastic housing has no place in a Premium priced mixer, especially when they advertise that the mixer can handle heavy bread dough. Finally, check the bearing seats, when the worm gear failed it may have also damaged these seats. It happened on my Kitchenaid. Good Luck!
ricardok45
Posted on Dec 31, 2008
  • 248 Answers
SOURCE: I own KitchenAid RRKP50 350
I belieive i"ve found what you need at -the gourmet depot.net-click on worm gears on the list on left side of page,parts with pictures and listings will come up.I think you will want the kp50 series 5 parts
Posted on Oct 12, 2010
Gear worm 9706730
look for the 9709557, worm gear as whirlpool has changed a lot of part numbers and they do it all the time, what is the serial number on your mixer? as after a certain date they also changed the worm gear from 53 teeth to 60 teeth so you can't use the older 53 teeth in a 60 tooth system, date is very important here, get back to us, a good place to look is mending shed .com they have there parts listed as to which model they work in, but I pretty sure of the part number that I gave you here. Hope this helps
Feb 18, 2013 | KitchenAid KP2671 Professional 6 Series...
My stand mixer's motor runs but the blades don't turn to mix the food
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
$15.00
Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
I have a KitchenAid stand mixer model KT2651X. It recently ground down the worm gear follower, which I purchased a new one along with a new worm gear because this is not the first time it ground down that...
It is not a good idea to modify anything in the unit to make part(s)
designed for another model fit. The KT and KP models have different
part numbers for the motor. I still don't understand why do you have to
change motor in the first place, just because the Worm Gear Follower
has to be replaced. Something is telling me, you have just purchased
the wrong part (Follower). The KT2651x is similar to the KP26xxx
latest models and the Worm Gear does not come with the Follower.
(i.e. they are 2 different distinct parts)
Jul 20, 2011 | KitchenAid Food Mixers
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
I own KitchenAid RRKP50 350 Watts since late 2004. and it stopped working last night. I searched internet and found that the worm gear is might be the issue. So I opened it and noticed that the tooth on...
Oct 12, 2010 | KitchenAid RRKP50 350 Watts Stand Mixer
Mixer does not rotate hook
Here is the exploded parts list fr a K45, perhaps it will help you replace the stripped gear inside the gear housing. It is probably the gear which is driven by the motor shaft.:
4162897 Worm Gear
It costs around $10 and can be found on the internet at places like:
http://www.amazon.com/KitchenAid-mixer-4162897-worm-gear/dp/B000TR6JEU
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Apr 08, 2010 | KitchenAid K45SS Classic Stand Mixer
I caught a spoon in my kitchen aid stand mixer. The mixer will not turn, and oil leaked out of the side
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear".
When you replace the worm gear, you should be able to see if you need more grease. This will have been the "oil" you saw escaping.
Jan 30, 2010 | KitchenAid Food Mixers
Just replaced the worm gear and cleaned out old grease adding clean new grease. Plugged the machine in and it will not run at all. The machine had been working but not well since I had stripped the worm...
Hi PEGNGEORGE. I can understand your frustration after getting all that work done for the gear and grease replacement just to find that it won’t run. Makes you want to scream. But before screaming, let's see what might be causing problems.
If your machine is not getting power to the motor, and you’re confident that the motor was not damaged by the stripped worm gear, which necessitated the replacement in the first place, then there are a few things that we can look at.
The easiest to check are the motor’s brushes. During your disassembly, did you remove either or both of the motor’s brushes (from the side of the mixer’s head)? If yes, then you need to check their alignment on the armatures’ commutator. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start.
If the answer is no, and you said the mixer worked, but not well after the worm gear stripped, that would lead me to suspect the problem most likely will be with your speed control assembly.
Since you’ve already replaced the stripped worm gear, I imagine you have your mixer’s Parts List manual on hand, but if you don’t, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. No. 25, Control Plate Assembly.
First inspect around the control plate assembly to ensure all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
You may already know about the website links below when you replaced your worm gear, but it’s always good to keep these sites in your ‘toolbox’. Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 14, 2009 | KitchenAid K45SS Classic Stand Mixer
Repairing a kitchenaid 6qt mixer and replaced worm gear. parts list shows a thrust washer needs to be there but it won't fit. after a closer look it appears that I have two back bearings for the worm gear...
ricardok45
Nov 22, 2008 | KitchenAid KP2671 Professional 6 Series...
Replacement parts for Wolfgang Puck stand up mixer
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page:
http://www.wpcookware.com/categories.asp?cat=32
Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
Jun 20, 2008 | Wolfgang Puck Stand Mixer
Food Mixers Logo
51 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
