West point wtw-500 is not cheng the programs
For start there is no problem but after wash its not change the program to rains and spine.
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Jan 24, 2013
Boola-Boola
  • 8 Answers
SOURCE: not fnishing wash cycle!
Erratic behaviour in wash programmes can often be due to clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme.
Posted on Jan 04, 2008
SOURCE: drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
Posted on May 17, 2009
SOURCE: Problem with spining during programs.
Try these solutions
I've just tested the water pressure pipe - pulled it up so that it was straight and that seemed to do it.
Posted on Apr 30, 2010
  • 30 Answers
SOURCE: the Samsung swf 8005 washing
try to operate the machine with nothing in it... see if it spins.... if it does this means your loads are not balanced properly...
Posted on Feb 07, 2011
rickyrt441
  • 4399 Answers
SOURCE: I have a westpoint washing
Thanks for choosing FixYa and welcome to the site. You need to check your spin bearing and the motor drive. If the noise is only during spinning, you need to check these. Anytime a washer makes loud noises during spinning, always check the spin bearing and motor drive.
Posted on Apr 24, 2011
My west point washing machine wtw 500 fully authomatic can no longer pump water out after it has finished washing. What is wrong with it?
first thing ti check is an obstruction in the pump impeller stopping it from turning (bobby pin , coin , bra wire etc)
check for a blockage in the hose outlet
Nov 29, 2016 | Washing Machines
Door locked red sign comes off
Has it ever run right? Are the water valves on? Is the selection by buttons or a touchpad? If buttons, make sure each is on a selection, not half way or in between. If touch pad, see if there is a reset.
Nov 28, 2013 | Indesit Washing Machines
Wtw-500 washer is being drained automatically after it is filled with water. It skips the washing process altogether
This sounds like drain hose is too low resulting in a syphon effect ,make sure its at least 26 inch above floor level.
Oct 31, 2013 | Washing Machines
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hi i have a Ariston avl 125 and my problem is that i start my machine and i wont stop again.... i just keep on spining ..... it takes in wather but keeps on spining at 2. wash..... hope that you can...
If this is a timer controller type then the contacts or the function to move on is faulty and needs a replacement. The inlet valve works to allow water and then the motor is struck on and not moving to the next cycle. Test the controller to confirm, check with a similar type before you order for one.
Sep 17, 2011 | Washing Machines
Bilink washnig & spining and machine not working
Thank you for using fixya.
Sep 14, 2011 | LG Washing Machines
Not fnishing wash cycle!
Jan 04, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
