Question about Ruud UBHC Air Conditioner
Transformer never shuts off
Rhllhm6317ja
    New Friend:
  • 22 Answers
Normally, the transformer in a system in active 24/7.
Posted on Jan 28, 2013
My furnace works but their is a humming coming from the transformer when it shuts off
Call an electricist. You might have some serious problem in the transformer. That ·humming" sound might be the transformer burning out!
Oct 05, 2015 | Heating & Cooling
Light transformer problems
DANGER WILL ROBINSON!
Transformers get hot when the load side sees a short (0 ohms) or very little resistance. V = I R or I = V / R. The voltage is a constant. As the resistance approaches 0, the current draw soars heating up both windings in the transformer.
Your transformer has an over temp sensor that shuts down the supply side before the transformer bursts into flames.
Find the short or replace the device. YESTERDAY!
Aug 27, 2014 | Intermatic Hardware & Accessories
Home stereo Phillip 708/37 is not getting power.i was told that I need to replace the transformer.cam you advise me how?
maybe not, are the fuses ok ? check fuses, make sure they are ok, also some transformers has a thermistor in between the winding of the transformer in series with the primary winding. Phillip do make their transformers with that kind of protection, just in case the transformer over heat it shuts down. examine the transformer look for the thermistor it is open.
Apr 07, 2014 | Audio Players & Recorders
Water running after heater shut off in humidifier
Hi check power at transformer / valve on water line could be stuck open clean valve out or transformer holding valve open
Dec 31, 2009 | Aprilaire 558 Humidifier
Need to bypass transformer on condenser
I assume that the indoor unit has a 40 va transformer, shut off power, remove outdoor transformer, wire the yellow and common to the contactor outside, make the same connections at the stat and indoor unit
Jul 08, 2009 | Heating & Cooling
Malibu transformer shuts down early
Well, you're overloading the transformer by 30 watts. It's doing what it's supposed to do when overloaded...shut down. It's the _other_ (works fine) transformer that you should worry about possibly starting a fire, since it's not shutting down when overloaded.
Mar 09, 2009 | Intermatic Malibu 121W Power Pack...
Microwave shuts off after a few seconds.
I am surprised that the GE seervice tech did not explain to you why the microwave will still cook. By saying that transformer is damaged or shot really means that the internal windings may be shorted together so the transformer no longer has as many good windings to produce the original power it did when it was new. That is pretty clear. It will still function a little but the protection circuits inside the microwave would start to shut it down when it overloads by trying to pull more current than the windings inside the transformer can handle. You can replace the transformer yourself if you are a do it yourselfer and are confident around unplugging the transformer with All Power Off and unscrewing a couple of screws that hold it in place. It is pretty straightforward you just need to find the correct transformer (maybe you can buy one from GE or go to www.mwoparts.com which carry all the parts in microwaves for all models especially name brands like yours. Taking the cover off is of course easy. Good luck. Let me know how you do or if I can help you in any other way.
Jan 26, 2009 | GE JVM1630 Microwave Oven
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Ruud UBHC Air Conditioner Logo
15 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
