Question about Video Cameras
Camileo p10 firmware update - Video Cameras
I need to download bios updated FOXCONN G41MXE-K
hope this helps
Download Foxconn G41MXE G41MXE-K P10 motherboard BIOS ...
https://www.wimsbios.com > BIOS Updates > Foxconn
Download and update your Foxconn G41MXE G41MXE-K P10 motherboard BIOS - Foxconn_G41MXE to the latest version.
Apr 02, 2017 | Foxconn Computers & Internet
I have a Polaroid 10.1 inch p10 model tablet why does it reset itself every time I turn it off
Same problem called them and they said its a known issue and there is no fix as of yet. They said hopefully they will have software to fix it within two weeks. I already returned device twice they said it was with all p10's. U would think they would shut it down and reboot it at least before putting it on the shelf's. Smh
Dec 02, 2014 | Tablets & eReaders
Free download handy cam driver
Drivers
click the link, go to option 3 and type in camileo h30 camcorder
Jul 24, 2013 | Toshiba Camileo H30 Hard Drive Camcorder
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
My Toshiba Camileo x100 won't charge?
Try with normal USB cable &take out laptop USB port .actually I misplaced my ac adapter try for many solutions at I found this
Jul 02, 2012 | Toshiba Camileo X100 High Definition...
Ny Toshiba Camileo P10 is reading "card locked"
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 19, 2011 | Toshiba Video Cameras
I need a free to download instruction manual for the Toshiba Camileo S30 dvd camera
Try this website http://safemanuals.com/user-guide-instructions-owner-manual/TOSHIBA/CAMILEO%20P30-_E
I hope it helps....
Dec 30, 2010 | Cameras
Video Cameras Logo
435 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
