Question about FUJIFILM FinePix HS10 / HS11 Digital Camera
Tri pod thread
The thread on the camera housing is plastic and no longer can screw tri podon. Can this be replaced?
    Genius:
  • 1,019 Answers
I will say that a camera shop should not have any trouble taking care of your problem, they deal with this all the time.
Posted on Jan 25, 2013
I have a Ryobi CS 3635 chainsaw. The chain guide bar is held in place by 2 studs that screw into threaded sleeves embedded in the plastic housing . Somehow I have managed to strip these sleeves to the...
Contact you local Ryobi Dealer / Stockest, and obtain spare replament parts . Other options --- Ryobi Website ( Best ) Yellow Pages to find local Dealer
Mar 17, 2015 | Ryobi Garden
The threaded sleeves for the studs that hold the guide bar are stripped. What can I do to repair them?
remove bad studs with stud extractor and replace with new ones ?? or maybe normal bolts ?? (if in engine housing )
or in a bind ive even rethreaded them to fine thread (assuming course was old thread) with a die and used std fine nuts on them as well .
if studs go in plastic case/frame then case needs to be disassembled and then studs press out other direction
Mar 16, 2015 | Garden
How do you replace a GE Spacemaker Oven Profile JVM1490WD003 handle ?
usually you need to demount the front panel
then remove its face unit as it will have a back guard unit
so they split apart with screws usually counter sunk machine screws
then the front unit section will have the handle attached
de mount it and replace and back step
i find if i place all the screws like a map of where they came from
then when placing a screw in metal or plastic
turn the screw anti clockwise {to the left}
till it clicks down and drops a bit
you get a feel for it so practice
once you do this you can almost guarantee your on the correct threads when you wind it clockwise {to t he right} to secure
esp important with plastic
if you drop in the wrong thread you end up with a unit thats plastics holes
no longer hold the screws turn turn isnt good
when you can use this trick
Aug 14, 2014 | GE Profile Spacemaker Over-the-Range...
I have a Quantaray QSX 9502TM tri-pod. I managed to lose the piece that screws into the bottom of the camera which allows the camera unit to be fastened to the tri-pod. I need to replace it. Can you help...
Good news! You can fix this very easily! The threads for tripod to camera mounting have been standardized for decades!
What you require is a 1/4-20 bolt of any type. You can go to any hardware store and find a huge selection.....many will even have a knurled knob on the end for hand-tightening. Places like Home Depot have large bins with just about every type bolt imaginable.
THE most IMPORTANT thing is choosing the correct length. Too long, and overtightening can damage your camera. Along with your bolt purchase, get a matching 1/4-20 nut to act as a backstop so you do not screw it in too far. You only need to have the bolt screw into your camera about 1/4" to secure it. You can also add a 1/4 inch flat washer to keep the nut off your camera's finish. Your bolt needs to be long enough to go through your tripod mount and then into your camera.
FYI- The "1/4-20" designation means that the bolt is 1/4 inch in diameter, with a thread "pitch" of 20 threads per inch.
Good Luck, and Thank You for using FixYa!
May 08, 2011 | Cameras
Jet bore threads not holding properly,side covers,breaking system
The jet bores are supposed to have a plastic liner near the outside of the bores that grips the jet screws to hold adjustment. You could try inserting a piece or two of thin plastic fishing leader, then inserting the jet screw. Don't insert so much leader that the material gets into the pointed end of the screw area as it will plug the jet. Any other threads that are not holding after being properly tightened can be be restrained by applying 'Loc Tite' thread locker fluid (from an auto parts house) to the threads before putting things together. Does the machine seem to have excessive vibration? Investigate the problem if it does. Hope this helps!
Apr 26, 2010 | Husqvarna Chain Saw 20" Bar
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Camera turns on, beeps, turns off.
Same Issue here!!! Must be a Optio thing...
Feb 17, 2008 | Pentax Optio S7 Digital Camera
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    FUJIFILM FinePix HS10 / HS11 Digital Camera Logo
    Top FUJIFILM Cameras Experts
    Tony
    Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
