Question about BURY System 8 Take and Talk Cradle for iPhone 4, 0-02-22-0292-0
Bury system 8 manual - BURY System 8 Take and Talk Cradle for iPhone 4, 0-02-22-0292-0
Can't locate fuel injectors on mazda rx 8
Hi. They are buried way down on top of the engine. Its just a matter of removing everything directly on top of the engine to get at the fuel rails. Just out of curiosity why are you removing them?. Jon
Dec 09, 2013 | Mazda RX-8 Cars & Trucks
The drip system in the older house that we just bought isn't working. I found these valves buried under a bunch of dirt and made sure the switches in the on position. The electrical timer is working,
There is usually a manual screw you can turn to open the valve. you should have around 19 volts ac at the solenoids. also you can unscrew the solenoid and the valve should open.
Mar 19, 2013 | Garden
I don't have personalize option in desktop right click menu
It is very buried in Win 8. It took me a long time to find it.
Feb 25, 2011 | Dell Computers & Internet
I've just bought a new Uni take and talk Nokia
there are two cradles available for the 6300, one has two connectors should work when you put the phone in the cradle and switch on the key, the other has one connector and is bluetooth, this requires pairing, you will need to search for bluetooth devices and pair using code 1234. The use of steering wheel controls is not possible with bury car kit. hope this helps. dan
Nov 20, 2009 | 2007 BMW 525xi Sedan
Where is the blend door actuator located? Is it a
buried in the dash, about an 8 hour job.
Oct 11, 2009 | 1999 Oldsmobile Bravada
Onkyo 506 zone 2 no sound
I believe that you can only get analog signals thru zone 2 (i.e radio, cassette player), kind of a ripoff since they bury this info in the manual
Jan 03, 2009 | Denon AVR588 Receiver
Change a water pump
1. Remove negative battery cable
2. Open radiator valve - drain cooling system
3. Remove cooling fan and shroud
4. Remove belt
5. Remove water pump pulley from hub
6. Remove hoses from water pump
7. Loosen heater hose coolant return tube mounting bolt and nut.
8. Remove the tube. Lose the O-Ring.
9. Remove water pump mounting bolts
10. Loosen the clamp on the bypass hose.
11. Remove the hose as you pull the pump away from the engine.
Hope this helps
Mike
Jun 14, 2008 | 1994 Jeep Grand Cherokee
BURY System 8 Take and Talk Cradle for iPhone 4, 0-02-22-0292-0 Logo
41 people viewed this question
Top BURY Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a BURY Audio Player and Recorder Expert? Answer questions, earn points and help others
