Question about KitchenAid KERC507 Electric Kitchen Range
Where is the location of the temperature sensor on a kerc570 electric range
Kenmore electric range 911.95575. What part controls the oven temperature
It's a "joint venture" between the electronic oven control and the temperature sensor (temperature probe) located inside the oven cavity.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 26, 2015 | Kenmore Kitchen Ranges
After cancelling auto clean I received an error code F14
"F1-4" error code means "Runaway temperature, lower oven".
The first thing I would do is check the lower oven temperature sensor. Pull the range out, remove the rear cover and locate the sensor wire harness to the control board. Measure the sensor resistance at the control board. Normally it suppose to be about 1100 Ohms at the room temperature. Also check the sensor wire harness and the sensor plug.
If the resistance reads wrong then replace the oven sensor.
If there is nothing wrong then the control board has to be replaced.Here is the sensor to order if it is bad.Here is the control board.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag MER5775Q Electric Kitchen Range
Oven keeps kicking off and the display comes up E2 F3. What does this mean?
error code for Bake Range Over Temperature, You may have a bad oven sensor, located inside oven at back left, or a bad board, Probably your sensor
Aug 28, 2010 | Whirlpool GY396 Electric Kitchen Range
F-3 is showing on my oven display while in use and the oven shuts off.
The problem is the oven temperature sensor, this is located inside the oven near the top. For diagrams and illustrations of your specific model go to www.appliancehelponline.com and enter your model #
Oven temperature sensor is open (above 3000 ohms)
Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Apr 09, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Electric range/oven that seems to be baking about 75 degrees below what the oven says it is at. Why and how to fix?
The oven temperature sensor is located in the top right or left rear of the oven on the back wall. It is about 3 inches long,silver in color. Turn off the power to the oven remove the racks. Remove the temperature sensor screws. Pull the sensor out carefully. Unplug the sensor plastic connector. Install the new sensor and secure the screws.
Nov 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
F3 fault code in oven mode--problem with oven temperature sensor
open the door and look in side in the left or right corner you will see a brass rod thats the sensor
Mar 02, 2008 | Magic Chef CER3740 Electric Kitchen Range
F1 fault
Here are the fault code for GE:
GE
Code
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
KitchenAid KERC507 Electric Kitchen Range Logo
54 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
