Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Hi i have a samsung 32 inch tv, model: le32r73bd, the problem is that i cannot change channels and the tv has stuck at channel 4, i cannot change any channel, i can not also reset, as i the option does not come up when i press the menu button. can someone please anser my question. Thankyou
  • anton999
    anton999 Feb 05, 2013
    hi i have done all of this, i have pressed info, menu, mute and standby and it still does not work, can some one please give me the correct information, i have also took the socket out and left if for 5minutes, still probllem.
    i need help, and can some one please help me, with the correct solution.
    Top Expert:
  • Samsung Master
  • 74,251 Answers
Make a hard reset to this set and check. Unplug it from AC mains wall socket, and re-plug it back after 5 minutes or so. This should make the set a hard reset. Good luck.
Posted on Jan 24, 2013
SOURCE: SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Posted on Mar 28, 2009
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
tvservice306
  • 458 Answers
SOURCE: Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
Posted on Aug 13, 2009
SOURCE: tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Posted on Oct 01, 2009
  • 6 Answers
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
My samsung lcd LE32R86BDX get image for only 1 sec than it's getting all black..with sound of the tv channel ...
Either your inverter has died, or part of your power board is fried.
Here is my step by step instruction for fixing your problem:
http://www.fixya.com/support/r4489343-flat_panel_television_repair_yourself
Sep 14, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I would like to find the hd channel on my tv model le32r8
After tune in any chanel.Check ur tv remote display button on the remote control.Any tv channels play in 1080i modes are in HD channels.
Aug 17, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Re: Samsung : LE32R73BD
hi yes there is, put the tv in standby, on the remote control press info, menu, mute, power the tv will come on with service menu just select reset,, if this don't work you will need to replace the maniboard thanks
shaun
Mar 22, 2017 | Televison & Video
My Samsung Le32r73bd TV has frozen so that I can only watch one channel. I have tried turning it off at the mains. Changing "source" and resetting the remote control but it has not fixed it. Any...
Unplug,replug ur cables,satalites,or telicoms boxes for about an hour or so.Replug these boxes back in let the software upgrade,the tv signal should be back to normal.Tries that,99% will solved this problems u have.
Mar 09, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Channel stuck problem
How long does it take (in seconds) before it changes teh channel? Because some TV's, if you have more than 10 channels, have to wait before they change because you might want to change to a higher channel Example:
suppose your TV has 99 channels but your remote has only buttons from 0 to 9. So if you want to switch to channel 7 the TV waits a little before it actually switch to 7 because there might come another nuber after the 7 as the TV doesnot know what channel you wants. 2 to 3 seconds should be the maximum delay.
If it takes more time, check if this can be changed in the menu, often there is a delay possibility in the setup menu.
If teh delay is over 4 seconds and you still have warranty on it, just return it to the vendor.
Jan 16, 2009 | Samsung 21" FLAT CRT COLOR MONITOR
go to reset
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
PROBLEM WITH TV
if your cable signal is poor , noisy, then it may not switch channels easily or at all.
Feb 17, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
226 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
