Question about Indesit W 123 Front Load Washer
Indisit wm 12 x door failiure - Indesit W 123 Front Load Washer
  • Indesit Master
  • 17,130 Answers
Click this link : Door lock
Posted on Jan 24, 2013
The lock on the door has broken how much is a replacement
Hi Janine, door locks don't cost a lot I have had to buy one a year ago it only cost me £8-00 i fitted it it was easy,but again it depends on the washing machine type mine was an Indisit and it again depends on if you are fitting it or you are getting a washing technician in.
good luck
Mar 01, 2015 | Washing Machines
Hi there - I have an Indisit IDL 705 model and it will not start. There are no warning lights and I have checked all of the suggested potential reasons for this including, power, water and door. Thank you
If there is power , the door switch is good and the water pressure is fine then the possible fault can only be the program controller unit.
You will need to check the voltage on the board, check the panel settings and see if the program is executed. If not this seems the prime suspect.
Jun 14, 2011 | Indesit Dishwashers
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Replace brushes in an indisit washing machine
Remove the rear panel of washer.
Remove belt from motor, unplug lead to motor, remove earth wire.
Undo screws securing motor, and remove motor.
The brushes are located at the opposite end to the motor pulley, you will see a wire going to each brush.
Please rate my solution.
Thankyou
Feb 02, 2010 | Washing Machines
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Front door does not open after washon model wm 12x
firstly unplug the appliance,then take top off then with you hand reach down towards the door mechanism on the inside then feel for a lever or the cable and play around with that and the door will spring open,then check the door handle
Jul 15, 2009 | Washing Machines
My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Jun 12, 2009 | Hotpoint WMA74 Front Load Washer
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Washing Machine door locked with flashing red light above on/off button, the model is a Indisit WD12X, there no water in machine and pump is cleaned with no obstuction. can anyone help with this problem
Try turning off the machine at the plug for about 10 minutes or until the light on the machine disappears, then try to open the door.
Usually works for me.
Regards jonno
Apr 04, 2009 | Washing Machines
Indesit W 123 Front Load Washer Logo
16 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
