Question about Canon PIXMA MP240 All-In-One InkJet Printer
Mp240 : led flashing green and orange and the monitor lets see P
I can not do anything :
led flashing green and orange and the monitor lets see P and number 2
  • 1 more comment
  • Anonymous Feb 09, 2009
    yes i have the same problem some one has a solution ?????
  • pmandrup Mar 17, 2009
    Same problem what does the triangle symbol mean?
  • Anonymous Mar 19, 2009
    yes i do have the same problem only that a number 3 appears
    Problem Solver:
  • 4 Answers
Full user manual, that for some reaso does not come in the box, is available here:
http://www.generalmanual.com/down.php?link=aHR0cDovL2dkbHAwMS5jLXdzcy5jb20vZ2RzLzAzMDAwMDEyNDgvbXAyNDBzb3Ntd2luMTEwdXMuZXhl
Posted on Feb 16, 2009
My canon pixma ip4200 flashes orane 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
Canon PIXMA MP240 All-In-One InkJet Printer Logo
298 people viewed this question
old marine
old marine
