Question about E-Games Puzzle Master 1,000,000 for Windows
Will puzzle~master 1,000,000 work on vista ? the other numbers do not.
My puzzle~master 2 3 &5 do not work now that i have vista.Will the 1,000,000 work on vista ?
How can i get a serial number for izotope ozone 5 mastering app?
That is a music mixing app that sells for $500-1,000 bucks, not a wheelchair issue.
The best way to get a serial number for something like that is to pay for it. Unless you are asking for someone to tell you how to break the law in an open forum??
May 16, 2014 | Carex Lightweight Transport Chair...
How to get an number line?
g9h87sr6yi+egaaaabjru5erkjggg==
You can use the Number Line to help you to add:
5 + 3 = 8And subtract:
6 - 5 = 1It is also great to help you with negative numbers:
-3 + 2 = -1 -3 - 2 = -5
So if you get puzzling questions like "What is -6 plus 3" just use the number line!
Jun 23, 2011 | Computers & Internet
My Electronic crossword puzzles by RadioShack comes on but will not do anything. I just put in new batteries. I do not have my manual.
Adjusting The Display
To increase or decrease the display's contrast so it is easier to read,
hold down FUNCTION, then press /\ or \/ on the cursor pad.
Playing The Game
1. Press ON/OFF to turn on the game.
If you have not worked a puzzle since installing or replacing the
batteries, CROSSWORD MASTER appears. Otherwise, the display is as it
was when the game was turned off.
2. To start a new puzzle at any time, press FUNCTION and 1 (I), 2 (O), or
3 (P) at the same time. 1 is for beginner-type games, and 2 and 3
increase in difficulty. NEW GAME LEVEL 1, 2, OR 3 Y/N appears.
3. Press Y to start a new puzzle. A crossword grid with flashing cursor
appears (O).
Otherwise, press N. The display appears as it was when you pressed
FUNCTION and 1, 2, or 3.
4. Press (or hold down) /\, \/, <, or > on the cursor pad to move the
cursor around the puzzle.
5. With the flashing cursor in the desired location, press ? to see the
clue(s) for the word(s) in that location.
Any letters you already entered appear, along with a dash for each
missing letter. The number of letters appears in parentheses - for
example, (5) for a solution with 5 letters. If the solution includes
more than one word, the number of letters for each word appears in the
format - for example, (5, 3, 4) for a solution with three words.
If the flashing cursor appears at the junction of two words (across
and down), both clues appear, across first, then down.
6. Press ? again to return to the crossword display, then use the letter
keys to type your answer.
If the flashing cursor was at the junction of two words and you enter
the first letter of your answer, two small arrows appear in the
adjacent across and down squares. Before typing the rest of your
answer, press > or \/ (across or down) on the cursor pad to indicate
which word you are entering.
Press /\ on the keyboard to erase the letter just above, and < to
erase the letter to the left of, the flashing cursor.
To erase a word, hold down FUNCTION and press WORD DELETE (Z).
To spell check the puzzle at any time, hold down FUNCTION and press
SPELL (T). The [+] symbol indicates the location of each incorrect
letter.
When you complete a crossword correctly, GAME COMPLETED appears.
7. Press ON/OFF to turn off the game. The current puzzle is saved.
(EB 12/08/98)
Privacy Policy
Mar 30, 2011 | Computers & Internet
Puzzle Master's House won't open
You haven't solved all 132 puzzles
The game tells you (both in the trunk and in the save slot) how many puzzles you've both found and solved
Players who think they've solved all 132 puzzles usually just look in the game's puzzle list, see that the last puzzle there is 132 and mistakenly assume that they must have solved all 132 puzzles
The puzzle list only shows those puzzles that have already been found, not every puzzle
Unless the found/solved count shows 132/132, then the last puzzle house will not open
If the game says, for example, that you've only solved 131 puzzles, then you have to very carefully look through the list to find the missing puzzle number ... if you don't find it, look again (some players have had to look through the list multiple times before spotting it)
Once you have the missing puzzle number, check this walkthrough to quickly find where the puzzle is (if it's not in Granny's shack)
http://professorlaytonwalkthrough.blogspot.com/
There's a puzzle index down the right side of the walkthrough you can click on
On a side note, this walkthrough can also be used for more puzzle solving fun, by looking at those puzzles that are specific to the other version (US/UK) of the game (there's over 180 puzzles between the versions)
May 11, 2009 | Nintendo Professor Layton & the Curious...
Finding all 120 hidden puzzles...
When the game says that you've solved 131 puzzles, then you've solved 131 puzzles
Players forget that the puzzle index only shows the puzzles that have been found ... just because the last puzzle in the list says 132 doesn't mean that there's 132 puzzles in the list
You have to carefully look through the list to find the missing puzzle number ... if you don't find it look again (some players have had to look through the list multiple times before spotting it)
Apr 21, 2009 | Nintendo Professor Layton & the Curious...
Incorrectly installed 'egames puzzle variety pack' three times
in your search and download egames puzzule after then store in your system drive to installd properly, when cliking next in the installation see any other select options will come for that choose correctly for required in your windows vista to update to get the correct installation
Apr 15, 2009 | eGames Puzzle Variety for Windows
What is the answer to puzzel 5, 18, 23, 27, 28, 36, 37, 38, 41, 112. In professor Layton and the curious village.
Puzzle 5 -- Answer is Ten Times 10
Puzzle 18 -- Move Top far Right Match to Left of the Dust-- Move Middle Match slightly Left to make the Handle.
Puzzle 23-- Empty 8 (Litre Pitcher) into 5 (L.P) Empty 5 (L.P) into
3(L.P) then empty 3 (LP) into 8 (L.P) then 5 (L.P) into
3(L.P) then 8(L.P) into 5 then 5 (L.P) into 3.(Litre P.)
Pour contents from the 3 (L.Pitcher) into 8(L.P) You
will have 4 Litres in two of the Pitchers.
Puzzle 27 -- Bickering Brothers -- Sit them clockwise from the top
as follows -- 1-- 3-- 6 -- 4 -- 2-- 5 -- .
Puzzle 28-- Find the Dot. Bottom Point on the Right.
Puzzle 36-- Only 1 as the mouse you bought was a MALE
Puzzle 37-- Brother & Sister-- They were Twins Age--- 6 (SIX)
Puzzles 38 - 41 -112-- are all quite easy, just play around you will get the Answers.
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
Help me pls...
Am I doing your homework? lol
1. 0.90
2. 0.56
3. 0.600
4. 0.033
5. 0.071
6. 0.002
7. 0.0258
8. 0.8
9. 0.34
10. 0.0078
1. Nine Tenths.
2. Seventy Eight One Hundredths
3. Ninety Two One Hundredths
4. One Hundred Two One Thousandths
5. Two Hundred Seventy Six One Thousandths
Jul 06, 2008 | Audio Players & Recorders
E-Games Puzzle Master 1,000,000 for Windows Logo
37 people viewed this question
Top E-Games Video Game Consoles & Games Experts
James Wishart
Are you an E-Games Video Game Console and Game Expert? Answer questions, earn points and help others
