Question about Kenmore Microwave Ovens
Kenmore Solid State Microwave model 566 8878620 How to reset the clock
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: reset my clock
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you should call the dealer or store where you got the oven to see if they have a contact number for Swan.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore Microwave Oven - Clock dosen't work
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in and try again.
If that doesn't work, you may have a problem with the keypad, but your best bet is to check your owner's manual first.
If for some reason you don;t have yours, you can probably get it via the Sears site.
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
If you still have toruble despite using the manual, you may have a failed keypad. If so, please reply back or feel free to contact me directly.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 08, 2009
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Posted on Jul 11, 2010
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
I have a microwave model # R-308NW. When I press
if when it shuts off clock resets to first plugged in state, sounds as if control panel is being reset by something (failure of part, or power surge) if clock is still ok and maintains correct time , I'll bet if you notice the cooliing fan is not running correctly (by sound it makes) in those two seconds, this will over heat magnetron and shut off on thermal hi temp (safety) if so fan will need to be serviced by a professional
Sep 10, 2014 | Microwave Ovens
What year is my kenmore solid state microwave? Ive tried to look it up but i cant seem to find anything on it
All microwave ovens are required by law to have the date of manufacture printed right on the label that has the model and serial number on it. Look inside the microwave, usually just inside the door.
Jun 06, 2014 | Kenmore Microwave Ovens
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
The clock seems to loose approximately 4 minutes over a period of 12 hours.
You haven't specified which Whirlpool model you have, so I can only give a general answer which would apply to the same fault on any device with an electronic clock.
The only fix is to have the timer circuit replaced.
It's a solid state timer and non-adjustable, but can become inaccurate if the oscillator crystal goes out of tolerance. Considering the billions of timer circuits manufactured, there are remarkably few which suffer this fault, so you've just been unlucky.
Jan 14, 2010 | Whirlpool Microwave Ovens
Shuts off after maximum of 8 seconds. does heat when on.
Sounds like the controller board has failed, assuming a circuit breaker has not tripped or fuse has not blown.
If all you do is reset the clock, and then it looses time, regardless of using the microwave, then it points to the clock/controller board.
If this only happens when you use the microwave portion for a few seconds, I would be suspicious of the microwave circuit, where there are several components that could cause the failure.
Jan 22, 2009 | Kenmore 80593 Microwave Oven
Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
But please reply back with your full model number so we can help you.
Sep 15, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore microwave
You may need to hit Clear or Clock first, or open the and close the door.
Otherwise, your keypad may have failed.
Please reply back with your brand and full model number so we can help you.
Jun 22, 2008 | Kenmore Microwave Ovens
Microwave oven
I'd bet the first three digits of your model are 665? That would make it a Whirlpool.
Either way, the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
It may be a problem (such as a missing timing pulse) on the control panel. We repair these.
Mar 17, 2008 | Microwave Ovens
Kenmore Microwave Problem
"d" may mean demo mode.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
Oct 13, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
