Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Spilled laundry detergent into lint trap and blower
How do I remove the blower wheel to clean it?
  • Maytag Master
  • 2,272 Answers
Hard way.
You will need to take the whole machine apart and take the blower out to clean it.
As you progress, you will see what tools and steps you will be needing. About an all day job.
Easy way.
Unhook the dryer air hose and electric cord.
Move the dryer to a place that wil allow you to wash it out with a garden hose.
Tip the dryer forward onto it's face and from underneath, wash the blower out with a garden hose.
Please don't use a whole lot of pressure.
Should dry in a few hours.
Keep the water out of the rear where the heating element is.
About a 1 hour job, with out drying time.
Be blessed
Posted on Jan 24, 2013
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
  • 8 Answers
SOURCE: Need to clean out lint trap
No, the lint basket/grid does not remove from front panel. This is what drives me nuts about this dryer......the worst lint catch design on any dryer I've used. I have purchased several vac attachments to get down in there, but every so often I take it apart.
You have to remove the bottom lower front panel of the dryer. It's not extremely difficult, just time consuming. I copied and pasted how to do so below thanks to a poster from another site, as I'm not so good at explaining these things in writing.
" Unplug the dryer. Remove the two screws that connect the front panel to the lint trap housing.
- Open the upper cabinet dryer and unscrew the four screws that span across the rear of the control panel.
- Move the control panel up and be aware that you will have to detach at least one electrical connector to get the panel out of the way (This will allow you to swing the control panel to the left).
- Remove the five srews located across the top of the bottom panel (Previously hidden by the control panel).
- Swing the top of the panel out and gently pull up to remove the bottom of the panel from the brackets.
- Unhook the yellow moisture sensor harness 2 wire electrical connector on the lower right side which will allow you to swing the panel to the left. "
You can download the Service manual online. It has the photo's to show you how. Not sure if this site has it but some other sites do. If you type in the model # + service manual in a search  it should bring up several sites to get it. You may have to pay for it. I ordered one soon after buying the dryer.....you never know when you may need it and being able to order the parts and fix it yourself saves a bundle, especially when it's one small little $5.00 part that could cost $100 or more on a service call. The electrical connections inside the front panel and on the digital console are not difficult to remove at all. I wrote on the inside panels w/ a marker as I removed them the first time I opened it as to how they hook back up. You can also take pics as you go w/ a digital camera if you have one. The 3 plug in connectors on the logic board are 3 different sizes, so they only can go back in one way.
I just got finished putting mine all back together last night.......I had a chewed sensor harness thanks to a chilly tree rat thinking my dryer vent on the roof looked like a toasty place to keep warm.....not realizing he'd fall 20ft straight down w/ nowhere to go but into dryer doing some damage trying to get out.
Anyway, sorry if I wasn't very clear on things, as I said I'm not to good explaining these things in writing, but the service manual is a must.
Good luck and take care, Teresa ; )
Posted on Dec 07, 2008
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
SOURCE: There is a lot of lint below the trap. I want to
I have the same problem. If you find out the solution, please let me know. donjo1943@yahoo.com
Posted on Mar 02, 2009
  • 659 Answers
SOURCE: My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Posted on Apr 08, 2009
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
Why is there no air blowing out?
Sound like the Lint Trap and Blower area is impacted or a Bad Blower Wheel
Sep 15, 2014 | GE Profile Harmony DPGT750EC Electric...
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
Possibilities
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
Noisy dryer after cleaning lint
There is something caught up in the blower wheel. You will need to disassemble the dryer from the front to be able to get to the blower wheel housing to clear what ever you have jammed there and remove it. Everything is done through the front.
May 31, 2010 | Maytag Dryers
Iget alot of lint in my laundry cant find lint
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open). All dryers have a lint trap (building codes probably even require it).
May 15, 2010 | Amana NAV2335A Top Load Washer
The dryer isn't drying properly. It gets hot its not drying. Its a Kenmore Elite. Also the coil has been cleaned and its not catching lint.
Make sure the drum is turning and the blower is functioning. Vacuum out all air passages including the hose going to the outside vent. Remove the lint trap, and wash it in hot water and detergent to clean away fabric softener deposits from the screen. If the motor is not running, find out why.
Nov 20, 2009 | Kenmore Elite HE4 Electric Dryer
How do I removethe lint? Clothes are coming out with fluff...
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
Nov 05, 2009 | Roper RAX4232KQ Top Load Washer
Dryer shuts off on E-1 code..Lint trap has been cleaned as well as vent hose and vent riser to outside.
Check for brisk air flow at outlet of vent hose (hose disconnected). If weak, remove lint screen and retry. If now has brisk flow, clean screen in hot water and detergent.
Aug 01, 2009 | Dryers
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
753 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
