Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Echo from freeview DTV on panasonic DVDR - Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Connect lg m1962d for freeview
Hi, you should be able to receive it. There should be a button, either labelled TV or DTV, that will flick between normal ariel viewing mode or DTV.
Have you tuned everything in?
You should be able to get all channels.My Father in-law uses a seperate box with an indoor arial and gets everything crystal clear.
I fyou need more help - then please ask.
Tony
Jun 06, 2010 | LG Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
Cant get freeview
go to menu put it on dtv scan channels/if not its aerial
Apr 18, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
What is DTV??
HELLO
Basically DTV means Digital TeleVision. You select this to get your viewing through your aerial (Freeview) providing you have it tuned in of course. That's all it means.
Sep 10, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Have lost most of digital channels
I had similar problerm.
Solution was to go to Functions - to Others - to SETUP - select Shipping Conditions.
After the unit has been reset to shipping conditions, switch off.
When next switched on it will autosetup like when you first got it and all channels should then reinstall.
May 23, 2009 | Panasonic DMRES20D DVD Recorder
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
I HAVE A SAMSUNG LE40R7, I CANT GET DIGITAL CHANNELS ON IT ?
I TAKE IT YOUR WATCHING YOUR SKY BOX OR CABLE ETC THOUGH THIS TV..BUT YOU CANNOT NOT GET FREEVIEW..CHECK YOUR ARIEL PLUG GOING INTO THE BACK OF THE TV, THEN TUNE THE TV IN FOR DTV. NOT CABLE OR SKY ETC THEY WILL NOT NEED TUNED IN..THE MENU FOR DTV..IF THAT DOES NOT WORK..DO ALL THE OTHER TVS WORK OFF THE SAME ARIEL ON THE ROOF TO GET FREEVIEW ???
Nov 14, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
