Question about Rheem Water Heaters
Low water pressure
71-40db
  • pam sherry Jan 23, 2013
    sorry I thought i was searching. My problem is since they hooked up the water we have no pressure. Had no problems before with pressure but since we got a new mobile home this heater doesn't have pressure. if we try to do two things like fluch toilet and turn on sink the water from the sink dribbles out even if it is on all the way.
    Sergeant:
    Champion:
  • 426 Answers
Sounds like bad water lines
Posted on Nov 06, 2013
What's your question?Water pressure from tap is low.Can I pour water directly into the water storage tank?
Yes, water usually goes directly into the tank from the water inlet.
If the pressure is low going in, the pressure will be low coming out.
Feb 28, 2016 | Water Water Heaters
I have a new pressure switch but still have low water pressure
The pressure switch shouldn't be reducing pressure unless it is smaller that the water pipe. Pressure switches in water heaters are a safety device that activate when pressure builds up above a pre-defined limit. I'm guessing that the most probable cause of low water pressure is either not enough head into the water heater (this is the height of water pipe) or not enough mains pressure. Your best bet is probably to install an inline circulation pump with a flow sensor. This will automatically detect that water is being used and turn on to boost water pressure.
Sep 23, 2014 | Water Heaters
G20 Eternity hot water system. Exceptionally low hot water pressure - just happened. Any ideas?
http://waterheatertimer.org/Low-hot-water-pressure.html
Link above have general troubleshoot steps to determine possible causes of low pressure
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 05, 2014 | Water Heaters
Low water pressure
Copy following link for low pressure troubleshoot.
Requires water pressure gauge on water heater drain valve
Apr 21, 2013 | Water Heaters
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
Low water pressure
1) Copy following link for troubleshoot walk-thru:
2) Yes. Remove the heat-trap inserts from water heater.
3) Add comment and say where you are so far.
Dec 30, 2012 | Water Heaters
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
The water is luke warm and the pressure is lower than ususal.
We probably need more information to give a good answer.
You report 2 different problems occurring at once: Low pressure and Low temperature.
If this is tankless water heater, then Low pressure and Low temperature might be related, and you probably need a service technician to diagnose and repair cause.
If this is tank-type water heater, look at label on side of tank for type and brand of heater.
Is it gas or electric water heater? Troubleshooting is totally different for each.
Is water pressure pressure low on just the hot side faucet, or is cold side faucet affected too?
Are all hot faucets affected by low pressure?
If you have a dual handle faucet, open hot side only and check if hot water that comes out is hot as normal.
This will say if problem is pressure or temperature.
Tank-type water heater usually won't have both these problems occur at one time, but water heaters work in funny ways sometimes.
Add a comment to this post, or re-post your question with details so the experts can give a solid answer and not guess.
Also you can post water heater questions on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Water Heaters Logo
18 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
