How do you relight the pilot on an itt reznor furnace model eedv125
billyvangogh
  • 108 Answers
SOURCE: Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Posted on Nov 01, 2009
Testimonial: "I checked the pilot light and it's clean. I will have to check the chimney next week but thanks!"
farfield
  • 462 Answers
SOURCE: I have a coleman furnace with a pilot light that
Remove the burner and gas valve from the furnace and use compressed air to blow the area under the pilot area ans all around it. The dust and stuff usually cause a condition called "Lazy Pilot" and the flame is probably not going in the designed directions. While you have it out Id replace the thermocouple with a new one reassemble and re-lite and note the difference. The flame should be mostly Blue and no yellow (or vary little at the top end of the flame only) Orange in the top area indicates a good burning flame and the closer to the base the bluer it gets.
While you have the burner out look inside and inspect the inner heat exchanger for cracks or rusted open holes there should be none. Turn on your fan while inspecting and see if you feel the steady blow of air from it inside the heat exchanger indicating a hole. Don't confuse the air that may come down the flue with the air from the blower though. A little breeze is expected from this.
This will take care of over 90% of the problems with the "Blow out" symptom.
If you still have problems you can try and "turn up the pilot". Usually a screw close to the pilot tubing is covering the adjustment screw. Put some soap bubbles around it so you can see if it leaks or not and turn the screw out for more flame (CCW) and in (CW) for less.
Hope this helps Please grade me accordingly and good luck.
Posted on Mar 11, 2009
billyvangogh
  • 108 Answers
SOURCE: reznor model# f125 pilot won't stay lit. i
Make sure the pilot is clean (Blue flame fully enveloping the top portion of the thermocouple) if its dirty the pilot will be yellow like a candle and barely touching the thermocouple ...quick fix is knock the pilot with a screwdriver...gently tapping it...knocking the dust out and getting a better pilot....the pilot could also be too small if its not making good contact with the thrermocouple....there could also be an Auxillary limit wired into the thermocouple which when open will prevent the magnet from staying closed....if all looks fine then the Gas Valve itself is likely gone (The magnet inside is not field repairable)
Posted on Oct 25, 2009
  • 3250 Answers
SOURCE: Pilot blows out when furnace burner goes off
trycleaning the pilot sounds like it too small an dthe heat from the burner is keepinh the thermocople going or try new thermocouple
Posted on Jan 10, 2010
  • 230 Answers
SOURCE: Is there any way I
You should never attempt to manually relight the pilot on this model. It has a hot surface igniter that is probably cracked. Most HVAC techs carry theses on their service trucks. However you may find one at an Ace hardware store in more rural communities for 30-$75.00. The higher priced ones are for the more universal replacements.
Posted on Jan 02, 2011
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
Blower Motor for Ignition keeps going after Furnace Stops
That sounds like a control board problem. If your spare is an exact match, I would try swapping out that board.
Feb 19, 2018 | Heating & Cooling
Pilot light will not stay lit om furnace
No pilot feed or it is dirty and or cob webs may be disrupting flow. Clean every thing and relight.
Oct 21, 2013 | Omega Trane Furnace Draft Inducer Blower...
Rheem gas furnace RGMA-125A: How to re-ignite pilot?
did not purge line , you need to purge line as it will take an age with just pilot .
Oct 05, 2012 | Heating & Cooling
Is there any way I can relight my pilot light by myself? The fan is on but the furnace is not heating up.
Dec 27, 2010 | Goodman GMS90703BXA Heater
Pilot blows out when furnace burner goes off. This happens every time when after the pilot is relighted and the furnace burner goes off
Jan 08, 2010 | Heating & Cooling
Hi, I have an amanna sv80 natural gas furnace, I lost power to my home , my question is will the pilot need to be re-lit or will the furnace restart on its own? Thank you
The pilot light will be fine it is gas. The only way you need to relight pilot light is if you turn off the gas. The furnace should restart itself when the power comes back on.
Dec 16, 2008 | Heating & Cooling
How do I relight Pilot for a Model # Carrier 58GP100-3 Furnace?
as the unit is very old there is no specific manual available for it to guide you but i will give u some link for extra help.
Nov 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
