Question about Frigidaire ATF6000ES Front Load Washer
Door lock wont engage
Washer door lock won't engage and the washer wont start. Just at end of one year warranty
  • 29 Answers
YOU MAY HAVE BROKEN THE BUTTON, A SMALL PIN LIKE PUSH BUTTON THAT PUSHES IN TO LET THE DOOR LOCK KNOW THE DOOR IS SHUT. YOU CAN USUALLY FIND A SMALL DIAMETER OBJECT LIKE WHAT IS IN A RETRACTABLE BALL POINT PEN TO SLIP INTO THE HOLE WHERE THE BROKEN PIN IS AS A TEMPORARY REPLACEMENT AND TO CONFIRM THIS IS ACTUALLY THE PROBLEM. IF IT IS, YOU WILL NEED TO REPLACE THE DOOR LOCK ASSEMBLY FOR PERMANENT REPAIR. DON'T SLAM THE DOOR SHUT BECAUSE THESE PARTS ARE MADE OF PLASTIC AND BREAK EASILY!
Posted on Jan 28, 2009
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Whirlpool washer won't start. Not a water problem. Door lock lift on or at times flashing. Think it's something to do with the door or panel.
At the right end of your panel you will find the 'end of cycle' symbol, to unlock keep this depressed for 3 seconds, this is the child lock feature. You do it again, and the machine locks.
Click if helped......
Apr 20, 2013 | Washing Machines
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Kenmore 11045981400 front load washer spontaneously fills if door is closed overnight. Then door won't unlock until machine is rebooted at power outlet
These things are getting more complex and electronic all the time and this does not help with the longevity of these units. It it telling you that there is a defective or intermittent door switch detected and when you reboot the unit it starts with all things at the zero point.
I had a high end Whirlpool washer that had so many things wrong with it by description of the service man that they replaced it after 4 years of use. No more 30 year old washers with all these circuit boards in there- isn't technology wonderful?
Oct 01, 2012 | Kenmore Elite 45986 Front Load Washer
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Crosley washer CFW7500KRO - Door lock won't stay engaged
Unfortunately I had the same problem and it ended up being the control board not sensing the switch being closed. Had to replace the control board
Sep 06, 2012 | Washing Machines
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Front loader not starting
First check if u can close the door with no or less clothes and see if the lock is engaged.. else if u find the door not locking see if there is any garments or threads blocking it.
Thankyou
Jun 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
294 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
