Question about Electrical Supplies
Need a fault finder for a Siemens thermostat
Room thermostat rdj10rf
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Is that line or low voltage? 240/120 or 24/12v
Posted on Apr 07, 2013
Why when my siemens RDJ10RF room thermostat has the arrow asking for heat does my boiler not fire up so i don't get any heating.The water heats up ok though?
You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 11, 2014 | Water Heaters
Siemens thermostat rdh10rf
If this is battery operated it could be the batteries at fault.
Apr 17, 2014 | Heating & Cooling
Siemens rdj10rf/set-gb problems with
There seems to be a common fault with the relay in the base unit box that's wired in to the boiler. If the black triangle is showing, the remote is demanding heat. If the two lights (green and orange) on the base unit are both lit, then it is paired and knows that heat is being demanded by the remote. However the relay sticks and doesn't actually supply current to the boiler. It can also stick in the on position so the house just keeps getting hotter. I've found that a couple of firm taps with my knuckles on the front of the base unit usually solves the problem temporarily, but if it keeps happening I think you need a new base unit (although I think you can only buy the complete kit).
Dec 18, 2012 | Heating & Cooling
Timer manual rdj10rf
RDJ10RFis AA battery-powered Siemens wireless thermostat, that works with RCR10/433 receiver.
Operation requires both products working together.
https://www.siemens.be/cmc/upload/cms/docs/sbt/hvac/Brochures_Datasheets_manuals/FR/01_Thermostats/Datasheets/N3072_RDJ10RF_EN.pdf
Oct 01, 2012 | Hardware & Accessories
I knocked our Siemens rdj10rf into the sink and now the display isn't working
1) Try to dry the display with gun drier for 15 minutes with a distance about 12 inch.
2) Wait after you dry by 15 minutes, and try again.
3) If the problem persist the display board is faulty. you must replace.
go to www.repairclinic.com and buy it.
God bless you
May 08, 2012 | Dishwashers
Manual for Thermostat Siemens RDJ10RF
THE BOILER READS ROOM STAT OFF, BUT IN ACTUAL FACT IT IS ON, PLS ADVISE WHAT TO DO
Nov 08, 2009 | AT&T Siemens S46 GSM Cellular Phone
PROGRAMMABLE ROOM THERMOSTAT
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Mar 15, 2008 | Computers & Internet
Electrical Supplies Logo
85 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
