Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Plantronics 200 earpiece
After charging my earpiece, I turned it on and the blue light just stay on and my phone cannot find it. I won't turn off either. Stuck.
  • Anonymous Apr 09, 2009
    my platronisc doesn`t connect with my nokia n70.
  • Anonymous May 20, 2009
    I have a Plantronics 220 bluetooth and after charging and trying to pair with my cell the blue light just stays on and it won't turn off either. Just stuck with blue light on.
How do I get the Explorer 200 Series to play the songs on my LG Lyric phone?
Posted on Apr 09, 2010
I have a plam centeo and i have a 220plantronic blue tooth but i dont have the key code is there way i could get it?
Posted on Mar 23, 2009
  • Veloxx21 Oct 06, 2010
    On the website's information documentation its labeled as 0000 is the key code
Low volume??
Posted on Aug 16, 2009
How do I pair the earpiece with a phone? I do not have my directions.
Well first turn your phone's bluetooth ON Then turn ON your headset.Wait for the indicator light to turn from red to blue. (if it doesn't turn off your headset then turn it back on) Press and hold the Call Control button until the indicator light flashes red and blue. (meaning it's starting to pair) Set your phone to find/add bluetooth device and select your headset from the list found When pairing is successful the indicator light should turn blue and your phone will confirm the pairing.
hope that helps....
Jul 08, 2011 | Plantronics Explorer 240 Bluetooth Headset
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
This is the second Plantronics earpiece that stopped working
I am sorry to say but the Plantronics are cheap and not well made. Sounds like you might have a weak battery and because of that it wont have enough charge to turn on. I myself have gone through many and now spent a little bit more and got a better earpiece.
Sep 08, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Feb 14, 2009 | Plantronics Explorer 330 Headset
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Sep 12, 2008 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
1,657 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
