Trane XR80 Furnace won't stay running
Hi all, I am working on my grandparent's Trane XR80 furnace, and it will only complete one cycle, shuts down, but the inducer keeps running (will not stop unless power is shut off even if I turn the heat off on thermostat) and after the house cools and needs heat again, the furnace does not come on, just the inducer keeps running. Inspection of the pipes for blockage revealed badly rusted out pipes - they had a leaky chimney that let water in the pipes and rusted them out. Do the pipes have to run all the way up the chimney for the furnace to work correctly? Can I rig this up for them somehow in the shorterm? The furnace will work for one cycle, but won't come back on. Is this related to the pipes, or should I try something else? Flame senser and HSI are good - I am thinking pressure switch or inducer motor? If I shut the power off and back on it will always do one cycle and shut down, but that inducer keeps running and the heater doesn't ever come back on. What do you think? Thanks in advance for your help! Mike
  • Heating & Co... Master
  • 2,515 Answers
It sounds like your flue work in your main problem get this fixed first then see how it runs , pipes should run all the way out of the chimney .
Posted on Jan 24, 2013
  • Mike Johnson Jan 24, 2013
    Paul - thanks for your help. I removed some of the old pipes and the problem is really bad. There is a 20 ft run to the chimney, then the length up the chimney and pipes are totally disconnected and rusted out. I cannot get to the chimney and obviously cannot tap in to the old pipes, so can I vent out a nearby basement window instead? The inducer motor ran all night and burned up, so I have a new one on order too.
  • paulcarew Jan 25, 2013
    good well done
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: i have a gmp100-4 rav
This problem is something that will not be covered in any manual....the board is defective...the relay that runs the inducer is welded together. this gives the inducer power anytime the furnace is energized... or has power...
The only way to fix this will be to replace the control board....the relay that runs this fan is part of the printed circuit board...not to say that the relay could not be replaced, but you would need to find a relay that matched with the same pin configuration, and then unsolder the old one and solder a new one in...
For most people the only fix is to replace the board...
heatman101
Posted on Sep 20, 2011
Therinnaiguy
  • 1420 Answers
SOURCE: the inducer fills with water and passes into the pressure switch
This unit is designed to condense, I suspect that the drain is blocked by some debris. Remove the larger hoses from the burner box and inducer motor and blow into them to clear any debris. Plug the end of the hose so you don't force water into either the inducer or burner box. Make sure that there is a vent on the drain just as it leaves the furnace cabinet. This will assist the drain to work properly and not cause the condensation to go up in the pressure switch hose.
Posted on Jan 04, 2010
  • 215 Answers
SOURCE: furnace shuts down intermittently when calling for heat
The flame sensor is not working properly, it is not allowing the ignitor to ignite, and this is making the system shut down, the flame sensor has obtain a build up of carbon, you will need to remove the flame sensor, and take a little piece of sand paper to remove the black carbon from the flame sensor stem, clean until the stem is shinning, replace the flame sensor and turn the furnance back on this will correct the problem.
Posted on Dec 14, 2009
heatman101
  • 43501 Answers
SOURCE: inducer motor runs cont. and
The relay on the circuit board for the inducer is stuck closed....
The reason you have to turn down the t-stat or recycle the power is that for the system to refire the pressure switch must open and then close again, which it does in either of those cases....
To fix the problem you will need to repplace the circuit board....
Check with your dealer for a new board or you can buy it on the internet...
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Posted on Nov 12, 2010
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
Lennox furnace won't start
Check the circuit board to see if the little 1 amp car fuse is blown, if it is replace it, if not, check to make sure the furnace is on and the door switch is engaged. if that doesn't work call a proffesional to come diagnose the furnace.
Mar 01, 2013 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
I have a gas furnace that won't stay running. It
Sounds like its the pressure switch try jumping it out some times you can fool it into working
Mar 05, 2012 | Heating & Cooling
My trane xr12 wont run. i checked the capacitor and its good but still nothing is working.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 02, 2011 | Heating & Cooling
I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
Your manual is here:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
Trane gas furnace with White Rodgers 50A50-474 board is flashing a 2 flash code which is a system lockout. The furnace blower contines to run, but the heat stops. I can reset the furnace and the system...
If this is a direct vent unit, check the PVC air intake at the furnace for debris. There is a screen at the furnace connection and as cold air enters into the burner chamber it frosts up on it. If there is any blockage, it restricts the air inlet. If the furnace ignites, it melts the frost and works fine. It happens mostly at night. Let me know if you find this. Thanks.
Jan 09, 2010 | Heating & Cooling
New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
404 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
