Question about Zenith C27A24T 27" TV
Zenith c27a24t video only on 1/2 screen - how do we fix?
Had to hook up to new sat receiver and now video show only on appx. 1/2 screen in what appears to be a box. went through menu screen and cannot figure out how to reset to full screen video. How can we fix this?
PERS_Malta
  • 45 Answers
SOURCE: Zenith A25A23W tv - Powers up - Black screen, no sound
You might have a bad power supply inside you TV or even a couple of dry joints. Patrick
Posted on Aug 27, 2007
jimbo4026
  • 50 Answers
SOURCE: Power Button
there is a line fuse inside the set should be a 4 amp, could be blown and if it would blow again you have a short on the board. (if u r to try it don't forget to unplug tv!)
Posted on Nov 28, 2007
Rifaa
  • 99 Answers
SOURCE: Dark picture after storm.
Dark picture? hmm.
meaning there is no brightness variation, assuming this is the fault I think U might be having low screen voltage. Check for high value ( around 2W) resistor, preferably from 100K to 680K on the "C" board or neck board. Post back
Rifaa
Posted on Nov 12, 2008
  • 121 Answers
SOURCE: tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Posted on Dec 13, 2008
mikeywaf
  • 346 Answers
SOURCE: Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
Posted on May 22, 2011
Enjoy your movies,
Mikeywaf
May 22, 2011 | Zenith C27A24T 27" TV
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Hooking up a convertor , when i have a vcr, dvd player
You can hook it up through the antennae system. Keep your dvr connected to the tv the way you had it. Hook up your TV rabbit ears antennae to the converter box in the connection on the left side of the box. Then hook up the antennae lead from the converter box to your TV on the right side connector. The only thing I'm wondering is, do you get stereo sound this way and does anyone know how to get it without hooking up the separate audio and video plugs? There aren't enough connections on the tv to hook up both sets.
Nov 12, 2008 | Zenith C27A24T 27" TV
Dark picture? hmm.
Rifaa
Nov 03, 2008 | Zenith C27A24T 27" TV
Black screen
This is a failure of the vertical circuit. It can be either poor connections at the vertical IC or a defective IC. If you can solder, you can fix this yourself. Please confirm that the model is C27A24T so I can get you the correct part number and costs.
Thanks,
Dan
Oct 30, 2008 | Zenith C27A24T 27" TV
I have a Zenith C27A24T the picture is out of focus.
If there is no other problem, he probably touched the focus adjustment in the back of the set. Open up the back and locate the flyback transformer (part with large red wire coming out the top). There will be 2 adjustment controls on it. One should be labeled screen, the other focus. Adjust the focus until crisp.
Dan
Sep 04, 2008 | Zenith C27A24T 27" TV
Missing Channels
you may have a bad tuner that is the part that changes the channels. If there is the input jacks you can use them to input a VCR or cable box and use them as a tuner
Jul 24, 2008 | Zenith C27A24T 27" TV
Image goes off screen
it requires a TV repair person to fix the internal problems.
Jul 08, 2008 | Zenith C27A24T 27" TV
2 Problems
this answer has given also to some one had the same problem.
"On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu." Good Luck
You can also get a user manual at the link below:
http://www.retrevo.com/s/Zenith-C27A24T-TVs-review-manual/id/277ag102/t/1-2/
Jan 20, 2008 | Zenith C27A24T 27" TV
Need help
scan below channel 2 and video should show? Or doesn't it have the audio/video jacks?
Nov 14, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
26 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
