Need instructions for lamp unit part number TY-LA2004
I installed the lamp but still get the message on screen to replace lamp.
  • 93 Answers
The projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
Posted on Feb 09, 2009
I am still having the same problem with the lamp hour reset....nothing is working that i have read
Posted on Nov 11, 2009
How to reset lamp timer panasonic pt-50dl54 ty-la2004
Consult the owner manual or call Panasonic customer service for the method for this model.
If I see one I do not know, I also will Google the model number with "reset lamp timer" etc. if the Panasonic line is busy.
Dec 19, 2012 | Panasonic PT-50DL54 50" Rear Projection...
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
JUST REPLACED MY LAMP TY-LA2004 HOW DO I RESET THE TIMER
hello
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
  • regards
    shaun
    Feb 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    Resetting lamp hour meter on panasonic tv
    press volume down on tv and pip or split on remote
    Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
    How to reset a panasonic dlp lamp hours?
    Try the following:
    If you need to get into the service menu, you can do so by following these directions:
    With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
    You can also click here to get more instructions if the above do not work. See post # 4.
    Jun 17, 2009 | Panasonic Televison & Video
    Panasonic PT-40LC12
    hi...
    Panasonic lamp timer reset procedure
    1. Press the power button to turn the unit on.
    2. There are 3 choices for this step, depending on the housing part number:
    A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
    B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
    C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
    3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
    OR
    3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
    When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
    Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
    Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
    Hi Mac
    Yes you can just take out the old lamp and install the new one in your existing lamp bracket. Simply unscrew , replace and screw back in.
    Apr 12, 2008 | Panasonic (ET-LA995) Projector Lamp for...
    1,049 people viewed this question
    jasbo
    jasbo
