Question about LG 60PC1D 60 in. Plasma Television
Tv will not turn on you have to try three times
    President:
  • 1,623 Answers
Its probably a few of the power capacitors are starting to fail, either that or fused resistors are starting to fail, have a tv engineer have a look to see if any of the capacitors are bulging, the parts aren't expensive so if they try and quote silly prices say thanks but no thanks and find someone who wont rip you off
Posted on Jan 24, 2013
  • 3 more comments
  • steve Jan 24, 2013
    thanks i will try that
    Martin what would a service call from a tech with parts and labor be 200.00 maxthis tv is 5 years old i can buy a 60 " sharp led at best buy for 899.00
  • Martin Murray Jan 24, 2013
    If you are going to do this yourself then i recommend you doenload the service manual for the tv from herehttp://www.mediafire.com/?z147k6dvdtiqh8... im in the process of uploading it now
  • kelly white
    kelly white Jan 31, 2014
    martin murray can you tell me where i may puchase capacitors or fused resistors and i live in the N.T australia
  • Martin Murray Feb 03, 2014
    LG 60PC1D Repair Kit, Plasma TV, Capacitors
    Be aware that the power board can hold power in it for weeks after use. So take extreme care when attempting repairs
    If you look at the following picture it shows you the capacitors bulging at the top, , the capacitors at the bottom are not bulging, the fused resistors can only be tested once removed so you are better off just replacing them anyway, once you remove the capacitors make a note of where they were on the board, and the value of the capacitor, it makes it much easier, when replacing them. You will be able to purchase all of them from ebay or amazon. In fact if you search for LG 60PC1D REPAIR KIT on amazon you can buy the parts you need
I just replaced the bulb last week, yet this time the TV will still not turn on and all three lights are still blinking.
It is possible that the replacement lamp is bad but more likely the TV has a protection mode that triggers wen the lamp goes out. Check the manual for ways to reset the lamp usage back to zero or a function that needs to be manually reset when the lamp is changed.
May 02, 2015 | Televison & Video
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
Power button flashes three times pause it does
problem solved with an inhouse repair man
Dec 16, 2009 | RCA Scenium D34W20 34" TV
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I turn the tv on the green light comes on three times but no pic
maybe you did the child lock which doesent allow you to turn the tv on unless u clck some buttons look in ur booklet and search for how to unblock the child lock or the 2nd try the turn on button and the ok button at the same time if it doesent work forgive me this happend to me as well
Mar 17, 2009 | Televison & Video
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Mar 15, 2008 | RCA HD52W59 HDTV Projection Television
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
LG 60PC1D 60 in. Plasma Television Logo
245 people viewed this question
Computer Repairing
Computer Repairing
