Question about Nintendo 64 Console
When turning on my N64, the power light turns on and I have a standard AV cable hooked up, but the video will not come through on the TV.
When trying out two different sets of red white and yellow AV cables, the screen stays black.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Step 1:
So you've eliminated the possibility of bad cables. Now you need to eliminate the TV and the Nintendo 64 itself.
Step 2:
For the TV, you can try another TV or make sure that you have the TV set on the right input.
Step 3:
If you can't make it work on an additional TV and you have made absolutely sure that the TV is setup correctly, then you may be looking at a broken Nintendo 64.
Posted on Jan 23, 2013
5 Suggested Answers
  • 52 Answers
SOURCE: Is my n64 broken?
You might have a dead N64 bro. Alot of quality games on that system too.
You can usually find them on Ebay for fairly cheap
Posted on Feb 11, 2009
benwabnick
  • 2404 Answers
SOURCE: N64 isn't working with Vizio HDTV...
Do this, hook it up to another tv just to make sure that the N64 is workig properly. If it works on another tv then you know the system is fine. If it doesn't work on another tv then it could be that you have dirty games and you need to clean the contacts and then reinsert them into the system and get them to work.
Keep the system on a known good working tv until you can get your games to work and display properly. You can clean the games by using a damp q-tip and wiping the contacts on the bottom of the game back and forth a bunch of times, there will probably be all kinds of black that comes off.
keep on trying games untill you get one to work and display properly, then go ahead and move the tv to the one you want it to work on and test it out and it just might work then.
Posted on Jun 26, 2009
totheark
  • 22 Answers
SOURCE: HI I JUST BOUGHT A
Had this same problem, just keep blowing into it and repositioning the game cartridge in the console until the console responds positively.
Posted on May 19, 2011
  • 894 Answers
SOURCE: I have all the wires
  1. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  2. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
  3. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  4. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here. It might be broken like it sounds like a power supply issue or and a laser assembly failure then.
Posted on Sep 04, 2011
Nintendo 64 has power but does not work
Bring the console in to Gamestop or Rock30 Games and have them hook it up to their setup and see if it works. They buy sell and trade n64 games and will have a n64 system already set up at the store. Just switch your console and cables with theirs until you find out what is not working for you.
Jul 27, 2012 | Nintendo 64 Console
TV Screen Goes Fuzzy Every 10 Seconds
Try using the av cables for N64 instead of using the rf switch then.
Apr 30, 2012 | Nintendo 64 Console
My n64 doesn't work on ch3
Well it might be that if your tv runs on digital cable like mine then the rf switxch part wont work then so I tried mine on the tvs in the basemant at my Aunt Gails house and the rf switch for N64 works there so you could use the av cables then instead of the rf switch.
12 STARS if this solution is helpful then
Apr 12, 2012 | Nintendo 64 Console
I dont know how to set it up
- First you need a rather old TV, like maybe before 2002, if you have one. Because on newer TVs N64 graphics are terrible !
- Once you have your TV, check to see if you have two cables with your 64 (if you don't something is missing !). One shaped like a little box on one end and an electrical plug on the other : you hook up the little box to your N64 and plug the device in the nearest power socket. The other cable has a a strange black and rectangular input that hook up in your N64 and 3 sockets that are red, yellow and white. Connect the latter on your TV by finding the same sockets with the same colours !
- Connect your controller to the console (it's the round-ish sockets in front of it)
- insert your game
- THEN turn on your console. Don't turn it on unless everything hooked up !
(if it doesn't work you may want to try the famous turn-off-the-console-blow-into-the-cartridge-put-it-back-and-try-turning-your-N64-again trick !)
Good luck ! :)
May 28, 2011 | Nintendo 64 Console
Bought a used gamecube....hooked it up properly, we think, but have audio only ...no video....suggestions
I suggest trying to use a different av cable from the gamecube to the tv, also try using the av cable you have on another unit, the cables are also exchangeable with the nintendo 64 av cable, so if you have a N64 laying around you can test with that cable. Good luck.
Apr 20, 2010 | Nintendo GameCube Console
Is my n64 broken?
Feb 07, 2009 | Nintendo 64 Console
Nintendo 64 HDTV
I am not an HDTV expert but I believe they are all backwards compatible so the fact it is HD should not be a problem. Have you tried a vcr or dvd player on the same hook ups? It is possible you are trying to use a video input that is already in use? I know on my TV I have the DVD hooked up with an S-video cable to "Video 2". Right next to the S-video hookup are the red, yellow, white RCA jacks. On my TV these can't be used when the S-video is in use so I have to have the games hooked up to the front panel "Video 3". I would disconnect everything and try hooking the N64 up in each input to see if you can find one that works.
Mar 02, 2008 | Nintendo 64 Console
N64 works but the Picture has loads of static
It sounds like it's most likely a problem with the AV cord you're using to connect to the TV or the ports on the TV where you plug it in. If you can, borrow a friend's AV cable and see if it works, if not then it's either a technical problem elsewhere or it is not hooked up correctly... Also make sure the TV is set to the correct input (Video 1, Video 2, channel 3, etc.)
Oct 17, 2007 | Nintendo 64 Console
Nintendo 64 Console Logo
120 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
