Question about Whirlpool Duet GHW9150P Front Load Washer
Dryer ,when i press start it try's to start .you then hit cancel and try start again sometimes it will start .also when it is running will stop before it's cycle.can anyone help.
  • Whirlpool Master
  • 17,129 Answers
Check the voltage to the control panel, If present check if there is moisture on the panel, Remove and reset all the connectors , check the harness to the panel. If these dont improve the fault it can be related to the control panel.
Posted on Jan 24, 2013
jsrock516
  • 5911 Answers
SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Posted on Apr 29, 2007
SOURCE: F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Posted on Sep 09, 2008
  • 1028 Answers
SOURCE: F11 Error
probably bad control bd remove top control mounts to rear rail ck all wiring to control first just f11 usually indicates internal control failure
Posted on Nov 26, 2008
  • 26 Answers
SOURCE: Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 19, 2008
  • 107 Answers
SOURCE: canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Posted on Mar 13, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Have a Whirlpool dishwasher model GU1200xtks. It is at least 8 years old. The dishwasher is malfunctioning. Sometimes the panel lights does not turn on but it sounds like the motor turns on automatically...
Bad touchpad user interface, is sticking in cancel mode causing unit to drain continuously... Replace both user interface and main control board due to software corruption
Jan 31, 2015 | Whirlpool Dishwashers
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How am i going to cancel previous print? i cannot print current page.. need your answer asap, thanks
Disconnect the printer from the computer and click on start and then go to run and type in cmd and hit enter,a black colored window will come up,type in net stop spooler and hit enter and again type in net start spooler and hit enter and tehn type in exit and hit enter.Now try to cancel the document.Whne it is done,connect the printer back to the computer and reboot both the machines. Still if it doesn't work then you can try by restarting the spooler services. Let me know if it has resolved the issue
Jun 20, 2011 | Brother HL 2140 Laser Printer
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 16, 2011 | Dryers
I have a 4 yr. old kenmore elite HE4 dryer. I put the clothes in and hit normal cycle. 41 minutes automatically comes on. I hit various buttons and nothing happens. I hit the start button and it finally...
if I am understanding the problem correctly then this website should work, if I am misunderstanding then the second one might help.
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~3088/forum_id_~409
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 03, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
Keeps stopping
I have a feeling you are buying a timer board.
Dec 11, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
