Laptop PC - DVD drawer wont open
The PC has a DVD loaded. When I press the eject button the drawer opens by 3 - 5mm, with vibration and then halts. Its a mechanical problem. Do I take the back off to fix, whats the risk of damaging the machine.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Just try this !!
there's an small hole beside eject button on your DVD drive tray.
take a small pin and push it into this hole move it around it will open.
this is for opening DVD drive manually if something goes wrong.
try this if doesn't help then goto service center. Generally they won't charge you for this.
Posted on Jan 23, 2013
Jastababe
  • 117 Answers
SOURCE: Eject button on Vaio won't work
t seems like people are having problems with getting the Fn Brightness and CD Eject Keys working when installing XP.
The following files and install method works here:
01. Install SFEP [AR51] (Right Click - Install SonyNC.inf)
02. Install Sony Shared Library [AR51] and Restart when prompted
03. Install Sony Utilities DLL & Settings Utility Series [BX4]
04. Install VAIO Event Service. Select Custom and Check VESUnique and Sound [BX4]
05. Copy AR51 Vista VESConfig.ini (from attached zip file) to folder C:\Program Files\Sony\VAIO Event Service
06. Start - Run services.msc
07. Find Vaio Event Service in the Services list and Restart the Service.
Your Fn and EJECT Buttons should now work.
Posted on Mar 31, 2008
Bappa170873
  • 505 Answers
SOURCE: DVD stuck in laptop
Use a pin and insert it on the small hole u see on one end of the DVD drive. Once you insert the pin you will see the tray coming out a bit. Applying little preesure pull the tray out and you are good to go.
Thanks
Posted on Oct 30, 2008
Dipu007
  • 2110 Answers
SOURCE: Toshiba L300 - disk drive tray wont open
Take a sharp object like needle and insert into the hole below the eject button...
Posted on Nov 29, 2008
Geekman
  • 32281 Answers
SOURCE: I got a cd stuck in the cd/dvd drive for my
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Posted on Feb 21, 2009
  • 8 Answers
SOURCE: HP Pavilion dv 1000 DVD drive door won't open
more info
Posted on Mar 22, 2009
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Dvd drawer
There should be a very small hole that you should be able to push a paper clip into. This unloks the mechanism even when powered off so you should be able to manouvre the trapped DVD out without it vibrating
Jan 23, 2013 | Fujitsu Computers & Internet
Dvd drawer locked and dvd wont play
Is it a store purchased dvd movie or is it a dvd that someone made and gave to you? Computers sometimes have problems reading cd's and dvd's that someone made. Try a store purchased movie dvd or music cd.
When you press the button on the dvd drawer it does not eject? Clcik Start/My Computer then Right Click on the DvD Drive and click Eject.
If it still does not open, take a Gem Clip (Paper Clip) and straighten it out as much as possible. Then look at the DvD Drawer and you will see a tiny hole that you can insert the Gem Clip (Paper Clip) into. Push the Gem Clip (Paper Clip) while you press the button on the Dvd Drawer and drawer will open. Don't worry about damaging or breaking something, that is why that tiny hole is there.
May 16, 2012 | Computers & Internet
Eject dell e6420
Eject what a Cd or DvD? If you can't get it to eject by pressing the eject on the drawer, try opening My Computer, then right click on the CD/DvD drive and select Eject. If it still does not eject you will need to straighten out a paper clip, get on your knees and look for a tiny hole on the cd drawer. Stick the paper clip into that tiny hole and push the drawer open.
Mar 29, 2012 | Dell Latitude E6420 PC Notebook
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Ejecting cd dell studio 17
Supposing that the Studio 15 / 17 has a slot loading drive:
You can either press the eject button above the keyboard (the touch sensitive one)
or
Go to 'Computer' in Vista and right click the CD/DVD drive. Then click 'Eject'.
This should work.
Jun 02, 2009 | Dell Studio 15 Laptop
DVD door won't open
try using a knife without the dvd player plugged in that will get out the cd
Sep 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
