Question about TruTech PVS31170S1W 17 in. LCD Television
Connecting antenna -- No Signal
I have a TruTech 19", PLV311995 (or s) 1, flatscreen TV/DVD. I can't find the manual (of course). I have a new RCA antenna, have hooked it to the TV in correct port, plugged both in, and can't get a signal. I'm sure there is one setting I don't know, help please.
PS: I know the TV works because it was hooked to Direct TV until a larger set replaced it.
  • Anonymous Jan 31, 2009
    Before step 1 in the quick installation the instructions say Make sure the RF aerial has been connected. Was I supposed to buy a RF aerial? I want to watch tv withoout cable. What should I do? I know nothing.
    New tv. Quick installation. Before step 1, there is an instruction to make sure the RF aerial is connected to the tv antenna imput jack . I so not have a clue. I want to watch tv without the cable. Do I need to buy an aerial?
    Problem Solver:
  • 12 Answers
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
Posted on Jan 28, 2009
  • brady_12 Nov 14, 2010
    I have the same TV, it is a crappy brand. I could not get barley anything over an antenna. I hooked it up to an antenna that another tv got a great picture and all the channels and got nothing on th trutech. It works fine with cable and satalite though.
    But I would not recommend anyone buy the brand.
I need install a RCA ANTENA IN A TTRUTECH TV
Here's the manual, antenna connections are on page 9.
TruTech PLV16320 User Manual Connections
I have no idea what you mean by "RCA" antenna.
Aug 07, 2016 | TruTech PLV16320 Television
Can't Get Antenna to Work
Try changing the input device to something you are sure, works such as a DVD player. If it works, check whether the transmission is compatible with the system in your TV. Go to menu and select the correct system such as PAL/Secam etc.
Aug 01, 2012 | RCA LCDS2022B 20 in. HDTV-Ready Television
Why does my Trutech say NO SIGNAL no matter what I do?
Video processor section should be checked. Contact any technician.
Jun 13, 2012 | Televison & Video
Hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Jan 21, 2010 | TruTech PM1919BXA1 19 in. LCD TV
7'' Trutech lcd tv and dvd not working
Pls. check your antenna line if it is still connected. Blue screen happens only if your
tv is not getting any signal from your indoor or
outdoor antenna.
Sep 21, 2009 | Televison & Video
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Trutech Code
i found that 0178 works for my 19 inch.
Mar 04, 2008 | RCA Universal Remote Control
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
Feb 18, 2008 | TruTech T650-DR DVD Recorder
TruTech PVS31170S1W 17 in. LCD Television Logo
503 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
