Question about Polaroid Televison & Video
Have portable Polaroid DVD player model # PDM-0855C it says loading then says no disk tried many DVDs in it and keep doing the same thing
Turns on and makes noise when it is loading then says no Disk tried many different dvds and the same thing happens
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
  • 36 Answers
SOURCE: Bad disk error no matter what disk is played.
try a cotton swab and len cleaner. rub a small amount on the laser eye and then dry it off. do thus several times. be careful and don't put to much on the cotton swab. it don't take alot
Posted on May 02, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
ejkudelka
  • 1188 Answers
SOURCE: polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Posted on Nov 29, 2009
  • 64 Answers
SOURCE: Polaroid Portable DVD player PDX-0758 reads bad
the only way is cleaning the optic reader.Just wet in alcohol a swab -almost dry- and clean it.If this does not fix the problem,you may have to replace it.
Posted on Feb 15, 2010
Dvd player will not play any dvd, shows bad disk
hi,
ur dvds laser pickup unit have some problem. first of all check the spindle motor which rotate the cd. there is chance to motor become faulty. when u insert dvd the motor will not rotate it the required rpm. if its ok then laser pickup unit have to be replaced
ok
Jan 01, 2011 | Polaroid PDM-0743 Portable DVD Player
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Polaroid Portable DVD player PDX-0758 reads bad disc for all dvds
Feb 15, 2010 | Polaroid Portable DVD Player PDM-0822BD
My portable Poloroid DVD player cannot not read
Is there a way I can download information how to fix it on my own.
Apr 25, 2009 | Polaroid PDM-0714 Portable DVD Player
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Lost power cord for Polaroid PDM-1058 portable DVD player
I've looked for the same thing and the only place I can find it is eBay for about $25
Nov 08, 2007 | Polaroid PDM-1058 Portable DVD Player
Televison & Video Logo
96 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
