Question about Garmin StreetPilot C330 GPS Receiver
Will not turn on
I have a Garmin Streetpilot c330. Cannot get it to power on. I have tried resetting it and it still will not power on . Any ideas
    Sergeant:
    Champion:
  • 373 Answers
Check and see if the unit is charge all the way
and if not it could be the buttom itself or the battery
Posted on Jan 28, 2009
The unit will not turn on, even when plugged into a power source. Unit was working fine a week ago. Garmin Streetpilot C330.
Have you checked the fuses in the power cable? There is a reset button under the front bezel. Try pressing that to see if your unit comes back to life too.
Cheers
Jul 19, 2010 | Garmin StreetPilot C330 GPS Receiver
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Display image has shifted, difficult to use
ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Mar 10, 2009 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
StreetPilot C330
Did you try the reset button after it come on.
Try that first.
Dec 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
