Question about Fujitsu Computers & Internet
Dvd drawer The dvd drawer contains a dvd and will not open. Press the release button and it opens by 3 -5 mm and vibrates.
There should be a very small hole that you should be able to push a paper clip into. This unloks the mechanism even when powered off so you should be able to manouvre the trapped DVD out without it vibrating
Posted on Jan 23, 2013
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
I can't open the cd drawer
If pressing the button on the CD/DVD drive does not open the drawer you can look for a small hole on the face of the drive, usually just below the drawer and about 1/3 of the way in from one side. Straighten out a paperclip and insert it into the hole. It should go in about a half inch then stop. Push a little harder and it will travel farther in and release the drawer.
Nov 02, 2013 | Computers & Internet
Laptop PC - DVD drawer wont open
just try this !!
there's an small hole beside eject button on your DVD drive tray.
take a small pin and push it into this hole move it around it will open.
this is for opening DVD drive manually if something goes wrong.
try this if doesn't help then goto service center. Generally they won't charge you for this.
Jan 23, 2013 | Computers & Internet
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Stuck dvd drawer
Unplug the player. look on the back and bottem for a small hole. stick a straight paperclip in the hole, and the drawer should open part way.
Jun 28, 2010 | Mitsubishi DD-8030 DVD Player
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
The dvd drawer will not open on Bose 3-2-1 system. When you push the button to open the dvd, the display say ''opening'' but it does not open. There currently is a dvd inside.
That happens when you close the drawer instead of pressing the close button  you can skip gears and it would have to be taken apart and re-calibrated.   Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front  (assuming this uses a drawer).
Nov 09, 2009 | Audio Players & Recorders
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
Cd drive
1.If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
2.Double-click My Computer .
3.Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
4.If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
5.If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
6.Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
7. If the door still does not open, do the following:
1.Close all programs and shut down the PC.
2.Unplug the power cord from the power outlet.
3.Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary (see Figures below for possible locations).
NOTE: On some models it may be necessary to remove the front panel to expose the manual release hole. Check the documentation that came with your PC for information about removing the front panel.
NOTE: On some models the release hole and the drive activity LED look similar and are about the same size. Do not force the paperclip into the hole if it does not go in. Make sure that the hole is not actually the LED.
Figure 1: Possible location of manual release hole
Picture showing possible location of manual release hole
4.Straighten the paperclip and insert it into the manual release hole until resistance is felt.
5.Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
6.Remove the paper clip and gently pull out the drawer until the disc is accessible.
7.Remove the CD and turn on the PC.
8.If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any edge of the computer's interior metal.
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface (like the metal frame of the PC).
1.Turn off the PC.
2.Unplug all power cords from the back of the PC.
3.Press and release the Power button on the front of the computer.
4.Remove the side panel.
5.locate the power cord that connects to the back of the CD or DVD tray that is having the problem.
6.Unplug the power cable and wait five seconds.
7. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
8.Replace the side panel and plug in the power cord.
9.Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Oct 25, 2008 | HP Pavilion a1330n (EL466AA) PC Desktop
DVD S540-needs password and screen scrolls
Open Disc Drawer
Press 99990
Close Disc Drawer
or
Open Disc Drawer
Press 99990 and then press enter/ok button (!)
Tray was closed independently by itself
and that's it. Enjoy!
Feb 19, 2008 | Yamaha DVD-S540 DVD Player
Computers & Internet Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
