Question about Samsung DVD-V4600 DVD Player/VCR
DVD tray won't open - Samsung DVD-V4600 DVD Player/VCR
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Toshiba MD14H63 dvd stuck in tray won't play region code error
Someone is going to have to open the unit and see if they can cycle the disc out by hand or not.
Nov 07, 2012 | Toshiba Televison & Video
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
Problem with the tray.it is not working properly and cant come out
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual
God bless you
Sep 27, 2012 | Philips DVP-3005 DVD Player
Problem with the dvd tray
God bless you
Sep 27, 2012 | Televison & Video
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
CAN'T OPEN DRAWER
Hello
There is a motor along with belt to control the disc tray for every DVD player. If this belt or motor [loading motor] has trouble, the tray won't come out or get into. Check these for perfectness.
Dec 12, 2011 | Philips DVP642 DVD Player
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Samsung DVD-V4600 DVD Player/VCR Logo
242 people viewed this question
Henry  Thomas
Henry Thomas
