Question about Omega Juicers 8006
Pulp too much pulp
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
Too much pulp in juice
You need a new slicer with a finer mesh.
Dec 29, 2009 | Waring JEX450 850 Watts Juicer
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
Replacement part needed
TRY 800 424 6783. PERSONALLY USING
A BREVILLE IS LIKE HANDLING A LOADED
WEAPON. MIGHT WANT TO CK OUT THE
OMEGA 4000.
May 06, 2009 | Juicers
Pulp splattered
Pour some water into it, at the very end.
Jan 06, 2009 | Champion G5NG853S Household Juice...
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Jan 05, 2008 | Omega 8005 Juicer
Clean the pulp
yes you take it off with the orange handle (separate part)- it fits in two holes and you tighten or loosen it.
Nov 28, 2007 | Jack Lalanne Power Juicer 250 Watts
Omega Juicers 8006 Logo
Top Omega Juicers Juicers Experts
David Payne
David Payne
Tom Chichester
Are you an Omega Juicers Juicer Expert? Answer questions, earn points and help others
