Question about Keurig B150 Office Brewing System
Does anyone know if the heating element in a Keurig Coffee machine can either be repaired or replaced?
    Master:
  • 249 Answers
Contact Keurig (866-901-BREW) for help
Posted on Nov 25, 2013
SOURCE: Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Posted on Jan 08, 2008
  • 79 Answers
SOURCE: Weak Coffee
I don't have any first-hand experience with this brand. However, it sounds like the coffee grounds are being partially bypassed by the hot water.
One clue that will help diagnose this is: does the carafe fill up to the amount of water that was in the reservoir? If not, that suggests not all the water is being cycled through.
See if the reservoir is completely empty at the end of the brew cycle. Look for any coffee-colored water in the reservoir at the end of the cycle. That would indicate, to me, a defective feed valve in the water path.
Posted on Apr 01, 2008
SOURCE: gasket - coffee grounds in coffee
That Gasket does fit over the puncture needle and NO do not crazy glue it. it is meant to be able to move. It prevents water and grounds from leaking out of the K Cup while in brewing cycle. Fit the rubber gasket just above the needed. It should fit snug over the plastic. This is about 1/2" above tip of needle. When you depress the needed into the K CUP it iwll reseat in its proper location. If it is not snug, call Keurig and they will send you a replacement gasket. Hope this helps.
Posted on May 05, 2010
cmccune04
  • 213 Answers
SOURCE: Need a new check valve for a Keurig B70 coffee maker
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
Posted on May 17, 2010
cmccune04
  • 213 Answers
SOURCE: Keurig replacement part
http://iwantsweetdeals.com/Top-Needle-and-Seal-Replacement-Part-Used-for-B40-B50-B60-B66-B70-B77-Brewers-P1227669.aspx
This is the whole assembly I hope this helps you!
Posted on May 26, 2010
I have asked my question twice It has not been answered yet WHY?
Hard call without seeing the failure.
No hot water? Does the heating light come on? If so, then the element is gone. Not economical to replace it.
Humming sound? What frequency? Is it a pump that runs continuously? If a tube is broke, it might be repairable. A bad pressure sensor will not be.
If the sound is a 60 cycle low hum you may have an electrical failure and possibly a dangerous machine. A wiring problem has a small possibility of repair.
Apr 25, 2014 | Keurig Elite B40 Coffee Maker
My keurig coffee maker will not heat water
Heater element burned out. Replace or get a new machine.
Mar 09, 2013 | Keurig Elite B40 Coffee Maker
Keurig won't heat water
Element may be damaged and in need of replacement. Return for service.
Oct 03, 2012 | Keurig B60 Coffee Maker
My Keurig Special Edition model has a ruptured heating element which is filled with a white substance packed around the inner element. Obviously, this substance has been going into our coffee. What is it...
I believe this is a ceramic filler... non conductive... takes the heat... and I dont know what the health risk is.
google digesting ceramic might give you an insight.
we know it's not asbestos... they dont use that product anymore...
Only thing else I can think of is Mica... they use that in toasters...
May 02, 2010 | Keurig B60 Coffee Maker
My Keurig coffeemaker shuts itself off, sometimes before I even brew a cup of coffee.
This is a heating problem.
What usually happens when heating elements start to go, is that they get thinner. This means that the same energy goes through a thinner wire - so it actually gets hotter than it should (like a fuse).
There will be an over-temperature switch that will cut out (to prevent a fire or damage) - so this is tripping off.
Replace the element with a factory original - and try again.
Check for any blackened connections at the element.
Mar 04, 2010 | Keurig B60 Coffee Maker
Keurig coffee maker is on, lights lit, machine said it is brewing but no water is coming out
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Feb 03, 2010 | Keurig Special Edition B60 Coffee Maker
My heating element is DOA on my Keurig B60. The unit is only 15
Nope! I googled the part # found on the element, and It's left me with no results. You need to remove one from a brewer with another issue and transplant it.
Oct 28, 2009 | Keurig B50 Coffee Maker
Ascaso Dream heating element gone - twice
don't have a solution, but i can say the identical thing has happened to me. my heating element has burnt out after only 19 months. i don't know if i should replace it. did you buy a new machine? if so, which one.
thanks
Jun 28, 2009 | Keurig B60 Coffee Maker
Keurig coffee maker?
The unit was "DEFECTED" by the company (understanding there was a fault with the original product). My partner is a Graduate of De Vry Tech's 4 Year Baccalaureate Program. He has thrown up his hands over ever successfully repairing this unit. It has something to do with ENERGIZING the hotplate and/or brew cycle.
It'll make a pretty night light on your kitchen counter.
Aug 29, 2008 | Keurig Platinum B70 Coffee Maker
Not saying "ready to brew"
Had this same problem. the "not ready" message flashes, unplugging the unit, pushing the power button have not impact ont he message. Keurig tells me this is an indication the heating element has burned out. I had ot call in a warranty claim and get a replacement.
Dec 28, 2007 | Keurig B60 Coffee Maker
Keurig B150 Office Brewing System Logo
213 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
