Question about Vehicle Parts & Accessories
Middle seat not bolted in, how is it meant to be?
  • Vehicle Part... Master
  • 3,904 Answers
I cannot see very well on your video but this is fastend to the floor from under the truck. My guess here is it was some sort of a carriage bolt with the nuts and washers tightening from the top. If you go to a parts store they will be able to pull up the specs and manufaturers replacement parts.
Posted on Jan 23, 2013
  • Orrin Finnefrock Jan 24, 2013
    Okay thanks, it almost looks like the holes in the floor are filled in
How do you remove middle row bench seat from a 2005 dodge caravan
Hi Amy, I'm AL the owner of Big As Auto Repair.
I look forward to helping you with your problem!
Amy, the middle bench seat is held in with four mounting bolts that must be removed from the legs of the seat. If you should need further assistance click here:
Auto Repair
Feb 27, 2015 | 2005 Dodge Caravan
How do you remove the rear seat in a 1999 Mazda 626?
heck for 2 bolts at the lower edge near the floor if no bolts push lower seat inwards and lift up it should pop up , use a large screwdriver.
Aug 23, 2014 | 1999 Mazda 626
How do you remove the middle bench seat on 2001 ford windstar? I already removed the 3rd row bench seat but the middle one has seatbelts attached to it and I can't figure out how to get them off the seat...
ok if you can see were they are bolt to the floor remove it from there and take the seat out with it,now if that seat is hold down by going in a slot and with a lever you pull or push to take out just do what you have to remove the seat
Jun 26, 2014 | Cars & Trucks
Do I need to use power tools to remove/reinstall the bench seat bolts?
yes tighting them by hand will be enough to hold the seats saftly, you shouldnt worry about it
May 05, 2013 | 1997 Mercury Villager
Rear middle seatbelt won't pull out in holden astra after I have folded down the seat , so can't return seat to correct position . How do I fix?
I agree with the above comments. I just had this same problem. Holden (Australia) quoted me AU$650 to fix it. I bought a T50 torx bit (like an Allen key)from supercheap auto for $11.
raise the seat back up as much as you can (I could only raise mine about 20 inches). Wriggle your hand in and find the bottom bolt of the seat belt clip (this will be the seatbelt clip for the side seatbelt) and start undoing it. It isn't hard, just fiddly considering you probably won't be able to see what you are doing. Once undone, you will be able to raise the seat.
I was still unable to loosen my middle seatbelt immediately. I came back to it a while later and it had freed up.
Simply a matter of then bolting it back in place. It was so easy - and I'm just a middle aged woman with no handyman/car skills whatsoever!
Jan 27, 2013 | Cars & Trucks
Where is the battery located on a 1996 Heritage softail?
Under the seat in the middle of the "horse shoe" oil tank. There are two, one on each side, large bolts that hold the seat on. Remove these bolts, lift the rear of the seat and pull to the rear.
Good luck
Steve
Oct 07, 2010 | Harley Davidson FLSTC Heritage Softail...
How do i remove the back seat of my 1995 cutless
you have to push down and towards the trunk the rear seats have s shaped hooks underneath
Apr 07, 2010 | 1995 Oldsmobile Cutlass Supreme
Seats
There are usually a combination of 4 nut/bolts per seat. You'll need a T55 or T50 torque bit and an 18mm deep socket to remove these. To access them slide the seat to the extreme front and rear. Once all nuts/bolts are removed tilt seat back and undo wiring harness from underneath. You have to remove both driver and front passenger seat to remove the centre console /middle seat.
Jul 30, 2009 | 2005 GMC Yukon
Just got an 2002 Chrysler Voyager. I can fold down the rear bench seat using the black lever on it but can't find a lever, or other release device to fold down the middle bench seat. How can this seat be...
i dont think they were meant to fold down but you should be able to take them out to haul bigger items. some of the vans they make are made that way so that you have to remove the seats rather than fold them down
Dec 06, 2008 | Chrysler Voyager Cars & Trucks
Middle seat selt belt 99 caravan
it is bolted to the seat frame you have to remove the bolt and nut. it's a torx bit size #60 and a metric wrench size 15 mm that you will need. please rate the solution...thanks
Sep 26, 2008 | 2000 Dodge Grand Caravan
Vehicle Parts & Accessories Logo
21 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
