Question about Acer AL1916B 19" LCD Monitor
'Input Format Not Supported' (please help me!)
When I last turn off my pc, my monitor is working properly, but now, when I tried to turn on my pc again, the monitor isn't working anymore. When i switch my pc on, the monitor is functioning properly like it should... The screens that appear according to are: >the words 'acer' >'microsoft corporation' at the bottom of the screen with a "loading" bar... >'Input Format Not Supported' - which is my problem now please help
  • Acer Master
  • 12,061 Answers
OK try booting up in "Safe Mode" Press F8 just after Turn on, when and if ya boot into safe mode then adjust your Video settings to say 1024x768x32bit and then reboot, if all good then when you are at the desktop, then adjust the settings to whatever you require... maybe 1280x1024x32bit.. Ya all good. If this doesn't work.. try the Monitor on another PC.. see if it works... if it does.. then maybe ya Video card is going/gone "Toes up" if not, then ya got a fault in your monitor, usually some sort of Power Supply problem or the like.
Posted on Jul 24, 2007
SOURCE:
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
I am trying to connect my pc to tv with vga cable but its telling me unsupported video format
There are two things you need to check for this to work. On your TV see what resolution is supported. This will be available from the menu options on your tv remote while on the PC input (for most TVs)
On your computer, plug into a known working monitor and change the resolution to the one supported by the TV, or possibly lower. Then plug back into the TV. You should now get a display if you have set the resolutions correctly.
Hope this helps
Feb 14, 2012 | HP Pavilion AMD Athlon II X4 630 QuadCore...
19LVWK (Black) LCD Monitor: input not supported -- I have tried F8,changing th...
No bent pins on the VGA cable? Bootup in safe mode, select VGA support and set the PC video resolution to he native resolution of this monitor, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | AOC 19LVWK LCD Monitor
Displays 'Input Not Supported' at start up om black screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Sep 20, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
Input not supported
IT sounds like the monitor got fried.. sometimes if the monitor is in the on position as the power comes back, the monitor gets an unexpected sure which can sometime damage the circuitry. You may be out of luck. You're only other option is to try using the monitor on another computer to see if it's just a weird connection issue.
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Input not supported
Vista Driver perhaps required
Try Acer Website
Jun 13, 2008 | Acer AL1916W 19" LCD Monitor
Sylvania 42" LC370SS8
Your TV monitor cannot support the format (scan rate) that your computer's display card is putting out. Go in to the computer's set-up for the resolution under the display properties and adjust the settings to support the TV monitor. Refer to the TV's instruction manual to see the supported formats.
When going back to the computer's display, the display format will have to be changed back to have the proper resolution.
TV sets are generaly not as good as dedicated computer monitors for use on computers.
Jerry G.
Apr 18, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
1,038 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
